Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-07-2018, 09:39 AM   #1
southern parts
southern parts's Avatar
6 cyl power steering
for 230/250 6 cyl. missing the lower adjusting bracket. the pump turns and the pulley is straight. $175 plus shipping.
member 64rust has first dibs.
southern parts is offline   Reply With Quote
Old 04-09-2018, 07:20 AM   #2
southern parts
Re: 6 cyl power steering
not heard from 64 rust so the first (I`ll take it)
Old 04-14-2018, 01:40 AM   #3
Stans69
What else would I need
Since Mine didn’t come with Power
Stans69 is offline   Reply With Quote
Old 04-14-2018, 07:07 AM   #4
southern parts
You would need a sector , lines , the lower adjusting bracket, and pulleys
Old 04-14-2018, 05:13 PM   #5
CousinTone
And Hydraulic Gear Box from most any GM truck up through 89 on some on a few through 91. Confirm the interchange!!! With this older pump and mount, you will need the earlier ones as the later have metric fittings with springs internal to them. There are adapters, but you need the gear box and that is the most important part and most expensive and then the adapter from Captianfab that is another expense. So you need quite a bit, but it's worth it Make sure you get all the info from the FAQ section for your year truck. There are a lot of complete upgrades on there. Take a look and you'll see the complete list of items required.
CousinTone is offline   Reply With Quote
Old 05-13-2018, 09:31 AM   #6
southern parts
yep, everything I said plus the frame adapter bracket. TTT
Old 08-02-2018, 10:27 AM   #7
southern parts
Last
