04-10-2018, 07:17 PM | #1 |
Active Member
New here
Hi all, recently picked up my 3rd 67-72 pu.
I purchased a 72 LB Custom Deluxe (pic in avatar). Truck has a 350 4bbl, TH350 tranny and factory air (currently inop). Question I have is how much trouble would it be to swap the TH350 for a 400? Brackets, braces etc. The last 2 I had (69SB & 72 Cheyenne LB) had the 400 transmission. Is it worth it to swap or just leave as is. Thx in advance.
Previous C10's 69 SB CST - sold 72 Cheyenne Super LB - sold |
04-10-2018, 07:35 PM | #2 |
Re: New here
I'd leave as is with a 350 eng personally. If you soup it up, maybe worth an upgrade, but if you're going to spend the $ on an upgrade, recommend a beefed up overdrive trans for lower highway rpm, unless you currently have a 3.07 in the back - in which case it may not really be necessary. For a driver that you aren't doing burnouts in (IF you aren't doing burnouts in it, that is ), a TH350 is a sound, reliable trans, not worth the effort to swap in my opinion. If you are doing burnouts, I'd still wait, if it fails, then that means it's time for a swap - so, maybe I should say it's not worth it to pre-emptively swap it as it may not be necessary.
04-10-2018, 10:12 PM | #3 | |
Active Member
Re: New here
04-10-2018, 11:15 PM | #4 |
Re: New here
I've run a TH350 behind a built Olds 455. They're plenty stout, and they have less drag than the TH400. I see no reason to change it.
Oh, I forgot to say... Welcome to the board!
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson Last edited by truckster; 04-11-2018 at 12:12 AM. |
04-11-2018, 02:33 PM | #5 |
Re: New here
To my understanding the fuel mileage with a TH400 will drop off as well.
I think this is due to the fact that they take more hp to run perhaps.....if that matters? Regardless tho', like the guys said....I'd stick the TH350..its a great transmission, tough and well suited to these trucks in a 1/2 ton with the 350. just my two cents. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
04-11-2018, 10:41 PM | #6 | |
Active Member
Re: New here
