#76 |
60-66 Nut
Re: 6 Lug Rear Disc with 15" Wheels and an E-Brake
I'll have to take a look and see if I can ship the trailing arm mounts in the same box as the rear disc brackets. I will let you know.
#77 |
![]() Join Date: Aug 2017
No worries if not, last night a local guy told me he has a set. I can paypal you the $$, is the price the same with the substituted parts?
Mike 1960 C10 Short Step 235 w/ 3 on the tree 1999 Mazda Miata <- Track Car 2016 Chevrolet Colorado z71 2016 Chevrolet Traverse - Wifes Car 2014 Honda CBR500R <- Also A Dust Collector 2009 Suzuki GSXR600 <- Stolen ![]() |
#78 |
60-66 Nut
The trailing arm mounts will fit in the medium box along with the rear disc brackets. I will send you a PM with ordering and payment info.
The base plates with a different hole pattern does not change the cost of the rear disc brackets.
#79 |
Has anyone found a set of brake lines and used them for this setup?
1969 C10 SWB, 68 Front Clip, Tired azz 350 w/built 700R4, 3.73 Peg Leg........... |
#80 |
60-66 Nut
So neither of the suggested hoses on the parts list are working for you?
#81 |
![]() Join Date: Apr 2006
I’m interested. How does the stopping power compare to the drums?
Kirk 72 Blazer CST 4wd highlander 66 Nova |
#82 |
60-66 Nut
Hopefully someone that has bought these and installed them will chime in......
#83 |
You don't make a kit to fit the Dana 44 GMC truck rear ends, do you? Does this fit them???
Chuck in Ohio *1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end *1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project *Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc |
#84 |
60-66 Nut
No I do not make a rear disc conversion for the 6 lug Dana 44. No, this bracket set is designed for the '64-'82 GM truck 12 bolt or '79-'87 GM truck 10 bolt. You are the second to ask about this in about a month, but before that I have not had a request for. If I were to develop a rear disc bracket set for the Dana 44, I would use the '79-'85 e-brake caliper. But now you have posted elsewhere discouraging people in regards to the '79-'85 e-brake calipers. I have not seen that they are hard to find, nor have I heard of anyone having a hard time finding them.
#85 |
Are these brackets still in production?
Thank you... |
#86 |
60-66 Nut
I fabricate all of my products everyday. This is one way I attempt to make a living. As long as the thread isn't closed, the parts are available.
#87 |
Any word yet on how to hook up the ebrake with this setup? Just curious if someone has determined a way to use the stock ebrake cables.
#88 |
60-66 Nut
I don't think the stock e-brake cables for your drum brakes can be utilized. You will have to go with a custom set of cables.
#89 |
![]() Join Date: May 2003
I have a stock 6lug 72 12 bolt 4x4 and would like to get a set of brackets for my application with gloss black powder coat. Can you pm me with a total cost and payment info. (PayPal )
Thanks Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#90 |
60-66 Nut
PM sent
#91 |
GM Addicted
I see you reference a GM metric caliper and showing photos of front calipers test fitted. What GM metric calipers are those if their not D52 calipers. Are they D154?
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#92 |
60-66 Nut
Yes the '78+ Metric calipers are the D154 calipers.
#93 |
Junior Member
![]() Join Date: Nov 2017
I'd like to order a set of brackets.
#94 |
60-66 Nut
#95 |
60-66 Nut
Here is a link to my new website and online store where you can see and purchase all of the products that I fabricate for the '60-'72 GM trucks.
https://customfab-cda.com
#96 | |
I am looking at converting to a 6x5.5 rear axle. Would it be as simple as swaping my axles and using the later chevy truck rotors as mention in this kit? Or do I need to change the spacing, calipers, and rotors? |
#97 | |
60-66 Nut
Sorry but no it is not that simple. There is no such thing as a 6 lug rotor that has the exact same dimensions as the Astro/Safari rotor. Everything must be changed including the brackets. The only bracket that is the same are the base plates.
