04-14-2018, 01:38 PM | #1 |
6l80 questions
Is there any difference between a 2013 and a 2015 6l80?
Found out my trans is a 2013, tuner says the pcm/motor is 2015 and won’t talk to the older trans, is this correct??
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-16-2018, 10:29 AM | #2 |
Re: 6l80 questions
Quite possible. The tuner should b able to do a segment change within the tune to make it work.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-16-2018, 01:27 PM | #3 |
Re: 6l80 questions
I’m being told that it needs a flash to get the two systems to talk, idk, paid one guy to do it and he leaves to get a “GM” scanner and then calls me with, mine won’t work on your issue....I’m looking for that jerk now...
04-16-2018, 07:27 PM | #4 |
Re: 6l80 questions
Check with Brendan at lt1swap.com. He seems to be very knowledgeable.
04-16-2018, 07:34 PM | #5 |
Re: 6l80 questions
04-17-2018, 09:02 AM | #6 | |
Re: 6l80 questions
05-13-2018, 09:47 PM | #7 |
Re: 6l80 questions
The ECU and tcm need to have matching operating systems. The best way to do this is with gm tis reprogramming service. Hptuners can do a full tcm flash as well but you need the right operating systems. I can help if you haven't resolved the issue yet.
