Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 04-21-2018, 09:03 AM   #1
whateverpratt
School me on Air Compressor Maintenance
I've been hobby wrenching on cars and trucks on and off for the past 20 years, and I finally got an air compressor. I picked up an old (1963) ~20gal air compressor super cheap. It works great.
What do I need to do for maintenance on this little sucker? I seem to remember people talking about draining them every now and then, and I'm guessing the compressor oil should be changed every now and then.
whateverpratt is offline   Reply With Quote
Old 04-21-2018, 10:00 AM   #2
truckdude239
truckdude239's Avatar
Re: School me on Air Compressor Maintenance
at work we use 2 80 gallon compressors piped tpogether only running one at a time other acts like a storage tank . we drain them every night i change the oil and air fitlers once a year with syn compressor oil both are about 20-25 years old still pumping along
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-21-2018, 10:18 AM   #3
Jrainman
Jrainman's Avatar
You can go to home depot they sell husky compressor oil , they have conventional oil , semi synthestic and full synthetic oils , you can use any of these oils , you should see a drain plug somewhere at the bottom or side of the compressors crank case , drain oil .there also should be a fill plug located high or top of the crank case , also there might be a sight glass on the side of the case somewhere fill new oill to 3/4 up the sight glass , if no sight glass fill to a little over half way up the crank case and your done , check belt tention also and Maintenance is done
Jrainman is offline   Reply With Quote
