Old 02-23-2018, 02:38 PM   #76
Hart_Rod
Hart_Rod's Avatar
Re: Bolt on hood brackets for Porterbuilt hood hinges.
Originally Posted by Blumenthal4 View Post
Hartrod, will your brackets work with the switch suspension hood hinges?
I'm not familiar with those hinges. Can you post some pictures of them? Thanks,
Rob
Hart_Rod is offline   Reply With Quote
Old 02-23-2018, 02:43 PM   #77
Blumenthal4
Really similar to the PB hinges.
Blumenthal4 is offline   Reply With Quote
Old 02-23-2018, 03:16 PM   #78
Hart_Rod
Hart_Rod's Avatar
I'm sure they will work, however I can't guarantee the exact hole placement with switches top hinge. So you might have to drill your own holes to match up with them. Let me know.
Also, what are you doing for rear tubz?
Old 02-23-2018, 07:09 PM   #79
Blumenthal4
Is it possible to get a set without the holes drilled for the top hinge?
I'm going to be modifying the stock rear tubs. I only had to raise the bed 6" to clear my chassis.
Old 02-23-2018, 10:19 PM   #80
Hart_Rod
Hart_Rod's Avatar
That shouldn't be a problem. Let me know.
R
Old 02-27-2018, 04:47 PM   #81
Blumenthal4
I'm in for a set without the top hinge holes! DM me the info and I'll send out PayPal payment. Thanks!!
Old 02-28-2018, 08:37 AM   #82
Hart_Rod
Hart_Rod's Avatar
Let me verify with my machine shop that this won't be a problem.
Old 03-06-2018, 11:13 PM   #83
Hart_Rod
Hart_Rod's Avatar
I'll have the brackets Friday.
Old 03-09-2018, 09:17 PM   #84
Hart_Rod
Hart_Rod's Avatar
I have your brackets in, Paypal is robhartley@aol.com. Thanks,
R
Old 03-21-2018, 06:43 AM   #85
Hart_Rod
Hart_Rod's Avatar
R
Bump....
Old 03-26-2018, 09:30 AM   #86
Pinchecharlie
Will these work with 63-66 as Well? Sorry if it's been covered. Thanks charlie
Pinchecharlie is offline   Reply With Quote
Old 03-26-2018, 10:04 AM   #87
Hart_Rod
Hart_Rod's Avatar
Unfortunately not...
Old 04-23-2018, 04:47 PM   #88
38chevyhotrod
38chevyhotrod's Avatar
I love those hinges, and because i am also lowering my suburban i would need to relocate my hinges.
The problem is that i am from the netherlands and the hinges are not available in my country. And if they could be shipped, it would cost a fortune by the time they arrive here.
This is why i want to attempt to make these my self.
Off course i would love a set af drawing, but i understand that i cant ask for that.
With a little try and error i think i can make my own.
Only problem are the struts. it is not easy to find the right ones.
And they are to expansive to try a bunch.
Would you mind sharing the details on the gas struts?
I would really appreciate it.
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 04-24-2018, 07:41 AM   #89
Hart_Rod
Hart_Rod's Avatar
I no longer have the truck that has the PB hinge setup, but I think you can find the strut part number on the PB website. Let me know if you can't.
R
Old 04-24-2018, 04:25 PM   #90
38chevyhotrod
Ok thanks, i will take a second look at the site.
Old 10-08-2021, 12:56 PM   #91
'67 C10
I know this is an old thread, but are these still available? Do they work with the current gen PB hinges?
'67 C10 is offline   Reply With Quote
Old 10-09-2021, 11:32 AM   #92
Pinchecharlie
Can't answer your questions but I have a set that are maybe 3 years old and only used for mock up that I can sell you if your interested. I ended up not using them. P.m. if you want .
Old 02-01-2025, 11:51 AM   #93
Cwood0425
are you still making these?
Cwood0425 is offline   Reply With Quote
Old 02-03-2025, 11:15 PM   #94
Hart_Rod
Hart_Rod's Avatar
Yes I am. LMk.
Old 02-28-2025, 12:07 PM   #95
PRCWest
Are this brackets still available?
PRCWest is offline   Reply With Quote
Old 03-02-2025, 12:41 PM   #96
Hart_Rod
Hart_Rod's Avatar
Yes they are. LMK.
Old 03-03-2025, 12:54 AM   #97
PRCWest
Yes they are. LMK.
Great,How can I get some? Is there a webpage or how does it work?
Old 03-03-2025, 01:44 PM   #98
Hart_Rod
Hart_Rod's Avatar
PM sent
