04-24-2018, 03:36 PM | #1 |
Starter goes "thunk".
350 sb. Lately when I go to crank the engine the starter just goes thunk but doesn't do anything. No noise, no trying to turn over- nothing. If I let off the key and try again it fires right up. When it does crank it sounds fine so I'm assuming the gear/tooth engagement is good. The battery cables are new,clean and tight.
Is this just a faulty solenoid I'm dealing with? |
04-24-2018, 10:55 PM | #2 |
Re: Starter goes "thunk".
The starter gear may not be engaging the flywheel completely which would be indicative of a failing solenoid.
04-25-2018, 02:44 AM | #3 |
Potentially a hot starter. Does it usually do it after driving for a bit? My 67 is having this issue now, so I’ll be putting a starter thermal wrap so it doesn’t get so hot from the headers. Also, the ignition switch may be going bad, mine was.
Customization is what you want it to look like -- not what other people think it should look like |
04-25-2018, 06:28 AM | #4 |
There is a difference between a thunk and a click . A thunk would indicate a loose starter . Have you gotten under there and grabbed a hold of it . A click would lean to a solenoid problem .
From what you say I would check starter bolts first . Starter can move and bind . |
