04-05-2018, 10:48 PM | #376 |
Re: show me your 73-87 lowered/bagged c10's
Few more pics, 6” drop up front now
04-06-2018, 11:33 AM | #377 |
Man this setup looks sweet! You say 22 / 24 setup? What are your specs if you don't mind me asking?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24. /Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat / SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed |
04-06-2018, 01:12 PM | #378 |
El Chapo. 78
"Life is too short to drive a boring vehicle". Later, Wayne |
04-06-2018, 05:31 PM | #379 |
04-06-2018, 05:33 PM | #380 |
04-23-2018, 12:09 AM | #381 |
Thanks. I'm loving how it's coming out so far.
04-23-2018, 12:12 AM | #382 |
Finally figured out just How Low it is
04-24-2018, 12:08 AM | #383 |
04-24-2018, 09:04 AM | #384 | |
Thanks man, it is just a Belltech flip kit in the rear. 3" drop spindles and Djm 3" springs up front, had 2" springs at first but swapped them out for some rake. Belltech Nitro drop shocks all around as well. Tire sizes are 255/60 15 front and 275/60 rear. |
04-26-2018, 07:12 AM | #385 |
04-26-2018, 10:29 AM | #386 |
04-26-2018, 10:53 PM | #387 |
My 83 again. The front lowered 6 inches but was dragging the frame n control arms. So had to put my back chopped spring along with 3 inch spindles. It’s at about 5 1/2 inches. Also now has 2 inch shackles in the rear.
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
05-04-2018, 10:39 PM | #388 |
Now with new wheels n tires.
06-17-2018, 08:04 PM | #389 |
Out for a cruise with the AC crankin
06-25-2018, 05:50 AM | #390 |
Reposting mine since photohacket took my other pics....cruising on the 2018 Hot Rod Power Tour......
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
06-25-2018, 10:03 PM | #391 |
at the beach
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
07-21-2018, 09:29 AM | #392 |
Plugging along slowly.
08-15-2018, 11:27 PM | #393 |
81 GMC. Beltech 3" spindles, moog 6454 springs cut one coil, rear axle flip. 235/70r15.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
08-15-2018, 11:40 PM | #394 |
How’s the ride with those 3/4 ton springs?
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
08-16-2018, 11:19 PM | #395 |
Fine, so far. I wish it would have come down another inch, though.
08-27-2018, 11:31 AM | #396 |
Great looking trucks in here.
I'm trying to figure out how to fit 325/50/15's flush with the fenders on my '76, as I'm going for a VERY aggressive meaty NASCAR look. I think 15x10 with 4.5-5" backspace will do the trick for the rears, but have no idea what I'll need to do for the fronts. Not trying to put it on the frame rails either- probably a 3/4 or 4/5 drop, depending on how much clearance I need during suspension load.
Strength is the Only thing that Matters in this world. Everything else is just a delusion for the Weak |
08-28-2018, 08:54 PM | #397 | |
8's on the front with a 4" BS are typical on a 15" wheel. You have to grind the control arm and its sit close to the tie-rod end. 10" wide wheel sit just outside the fender and doesn't look great imo.
'78 C10 Build |
08-29-2018, 09:39 AM | #398 | |
As far as the outside of the wheels, I've entertained the idea of cutting the fenders/bedsides and adding flares to accommodate the fitment if need be. I know it seems stubborn, but I will not be happy with the build unless I have 325's on all four corners lol. One way or another, I'll make it happen.
08-29-2018, 10:04 AM | #399 | |
'78 C10 Build Last edited by cruizin01; 08-29-2018 at 10:14 AM. |
08-29-2018, 10:10 AM | #400 | |
But hey- I can still get the look I'm after. This is pretty slick looking, though I'd go a touch lower. If anyone has his specs, I'd be interested in knowing them. https://www.youtube.com/watch?v=vL51VkIqQ0k
