Old 04-28-2018, 03:55 PM   #1
CRGRS 66
CRGRS 66's Avatar
Factory Clutch Bellcrank Pictures?
Hey guys, CRGRS 66 here, I am hoping to get some help from you guys with my clutch linkage, particularly the bell crank, and how it is mounted to the frame. I have a GM crate engine, just the regular 260HP 350, and the tapped hole on the block is in a different location than my old 66 283 was. . The 63-66 Bellcrank has a bend in it, the 73-87 Bellcrank is straight. I am thinking that I will order the 73-87 Bellcrank from Classic parts, but would like to see if the frame bracket on the 73-87's is the same as mine. Classic Parts lists the stud for the block as the same part number for 63 thru 87, so I should be good there.
Thanks in advance!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 04-28-2018, 05:50 PM   #2
IllinoisK30
Active Member
IllinoisK30's Avatar
Re: Factory Clutch Bellcrank Pictures?
Here is a picture of the one on my ‘77. Hope it helps.
IllinoisK30 is offline   Reply With Quote
Old 04-28-2018, 07:12 PM   #3
geezer#99
geezer#99's Avatar
Easy to build a bracket to mount the pivot ball too where you need it on your new motor.
Here’s some different ideas.
https://www.google.com/search?tbm=is....0.U9eu7NVbyGk
geezer#99 is online now   Reply With Quote
Old 04-30-2018, 11:38 PM   #4
CRGRS 66
CRGRS 66's Avatar
Thanks guys, that helps.
I think I have a plan, might be a while, but I will post up what I come up with.
Cheers
CRGRS 66
Craigerrr
