Old 04-29-2018, 02:19 PM   #1
NJKelly
Transmission ID
The shifter retention kit pictured. The outer tin piece which should swivel underneath the two pins cannot turn. The pin actually tops out and when I go to spin it it won't get past little Nubs. Pretty sure I ordered the right part but wondering if I made a mistake. If anyone can tell me if the retention kit is different for different Muncie Transmissions I'd appreciate it. I've attached pictures of the transmission as well.
NJKelly is offline   Reply With Quote
Old 04-30-2018, 06:55 AM   #2
68panelman
68panelman's Avatar
Re: Transmission ID
Sm465. If you're trying to put the retainer in dry, it will be difficult. Get it greasy and make it easy
68panelman is offline   Reply With Quote
Old 04-30-2018, 09:04 AM   #3
NJKelly
Re: Transmission ID
I'll try that, thanks.
Old 04-30-2018, 05:29 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: Transmission ID
You also have to push down on the shift lever while you are turning the retainer.
LockDoc
Leon
Old 04-30-2018, 10:32 PM   #5
NJKelly
Re: Transmission ID
Thanks, didn't see that anywhere. Good info.
