![]() Join Date: Aug 2017
Sway Bar and Air Ride
I recently installed my air ride setup and absolutely love it. Still adjusting to it and playing with the psi to drive around on. But I feel like the body roll got worse with the air ride and shorter front shocks.
So I'm curious anyone have suggestions for a front sway bar? I'm looking at a CPP Bar at the moment but wanted to get some suggestions before I order. What about OEM's that fit; if so what year? Which end links? Truck is a 1965 C10 SWB, cupped lowered arms, shock relocators in the back, CPP Track bar, 2600 Bags all 4 corners, shortened front shocks. Thanks Everyone |
Re: Sway Bar and Air Ride
I don't have an answer for the specific fit but do you have each bag set on separate valves?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
![]() Join Date: Nov 2015
Get a sway bar from a late '70s 3/4 ton Chevy. They are thick, inexpensive, and easy to find bushings. You will need the frame mounting brackets for a lowered truck, however.
Well I stumbled upon this yesterday and went ahead and ordered me a CPP kit. It was only $118 shipped so I went for it!
http://www.classicperform.com/tech_a...ar/SwayBar.htm I will update on the difference once it's installed. |
Where did you buy it from?
