how often do rear coil springs go bad?
On my 64 c10 I got pretty bad bouncing in the rear when hitting bumps, especially when hitting a bump in a turn. I think my rear coil springs are shot. Things I have done so far to try to correct the issue:
new shocks, new trailing arm bushings (rubber) , new panhard bar w/rubber bushings. I work at dealership and had the truck aligned this last saturday. I thought i found the issue as the thrust angle for the rear axle was +.37 deg (should be 0 deg). We got that right but I still got a bad bounce. Is there a common test as far as how many times the springs go up and down after pushing the rear bumper down by hand and letting it go? What do you guys think? |
![]() ![]() Join Date: May 2015
Re: how often do rear coil springs go bad?
usually new shocks helps with this...but you've already got that...usually when springs ,get weak/go bad, they start collapsing ...I wouldn't think thrust angle has any effect on a bouncy ride...is the truck lowered? that bouncy test is usually a way to check for worn shocks...you could have a bad set ..even when new...were they quality shocks or the el-cheapos?
#3 | |
https://www.autozone.com/suspension-...64_793522_7413 I know I bought white ones cause I painted them black. I'll have to see if I can find the receipt or #s stamped on the shock. |
Moderator
![]() ![]() Join Date: Aug 2011
I dont think bouncing is the springs, You may you need better (read Different) shocks.
The “bounce test” requires some effort. Go to one corner of the car and push down. When you let go, the car should bounce up, then settle back to at-rest height. If the car bounces more than twice, you most likely need new shocks. Also a vid on the subject - https://www.youtube.com/watch?v=BiW0ISi8N-w
#5 | |
Do the bounce test right after driving it. I've seen shocks go "limp" if they've sat for a bit and might need to be cycled a few times before they dampen like they should.
The thrust angle would probably be the panhard rod not being the exact length it needs to be for your exact ride height. They make and adjustable bar to help with that. Before buying new shocks, add a few hundred pounds of weight in the bed to see if the bouncing gets worse. If the shocks are bad they'll have a harder time controling the body movement and the bounce will be worse. If it rides better then the shock valving is too stiff for the amount of weight on the truck when unloaded and the shock isn't allowing the suspension to absorb bumps like it should.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
![]() Join Date: Jan 2011
Tire pressure and sidewall construction also can make it bouncy.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Fifty plus yeas is still a long time for truck springs. Even if they don't cause your bounce, they are probably worn out anyway.
Moderator
![]() Join Date: Dec 2012
These things are bouncy with no weight in them. That's the price you pay for driving a truck. Throw 500lbs in the back, it will ride great. Mine has old springs, new shocks, good used trailing arms with good bushings. Bouncy when empty, great with a load.
Full dress iron head small block. Delivered it across town, drove great. ![]() |
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
#12 | |
Thanks for everyone's help so far... |
Moderator
With brand new KYBs on mine, it feels bouncy. Until you load it. Not dangerous, it drives fine. At 5 or 55. Not uncontrolled bouncy like with worn shocks. No hopping, no skipping, nothing dangerous. Hope that makes sense.
Scrapper 1
I feel a set of Gabriel air shocks fixed my problem plus your rear bushing might need to be replaced
#15 |
One thing that makes this hard is what is bouncy to you? Bouncy to me is when you have bad shocks and it goes up and down many time before it stops. So is bouncy a floating feeling or it feels like it bounces off every bump in the road? If it is bouncing off the bumps in the road its the springs and they are just a bit stiff compared to what you are used to. These old trucks ride like trucks and not the cowboy caddy's they make now.
Jimmy
#16 | |
As far as the "cowboy caddy's", I do pre delivery inspections, which includes a test drive, on all the new cars here at work so maybe I'm a little biased as to what I'm expecting..lol, though I'm not expecting my 64 to ride like a 2018. I just want to make sure it's safe regardless of the ride. |
#17 |
I had a well worn out 68 shortbox. The scale guy yells 1.8 ton when I had it loaded with sand. It took all of that to plant it firmly down and I was probably lucky the wheels didn't fall off going over the Granville bridge in Vancouver. They drive good with weight on them. After unloading it was right back up to its usual height.
Driving that truck empty over the railroad tracks from work and it would really bounce around. Make sure your U-bolts holding the differential in are tight as mine was flopping loose. My 66 with 8' box has new springs/shocks and still bounces around like you describe. It's just the nature of the beast I think. Are the front end components good? Last edited by vince1; 05-02-2018 at 11:50 AM. |
#18 |
The weight split on these trucks is a good bit front and and will seem WAY different then anything you drive. I have a long bed with the tank behind the rear wheels and I can feel the difference between a full tank and an empty tank. Have you got a sway bar on the front? Many did not and that can make a sweeping turn fun at times. Your truck is safe and as long as you drive it like what it is and realize the limitations of the more than 50 year old design and what it was designed for you will be good.
Jimmy
#19 |
#20 |
#21 | |
A huge part of the problem with a truck is that the percentage of sprung (weight that the springs support) vs unsprung weight (axle, wheel/tires) is at a really disadvantaged ratio compared to a vehicle with a more even weight balance front to rear. That's half the reason why they ride better with weight in the bed. There's not enough sprung weight to keep the unpsrung weight settled and under control. I'm pretty sure that the factory coil springs are dual-rate. Check to see that the center part where the coils are closer together still have daylight between the coils at normal ride height with no load in the bed. If they've sagged any and the coils have closed up then you're riding on the part of the spring with a higher spring rate and it'll ride rougher. C10's had the option of standard or HD springs, yours may have the HD springs from the factory. Another option is to replace the coil springs with Airlift D2600 bags. They won't need much air pressure to pump up to ride height since it's a larger bag so the spring rate will be lower. A sway bar won't help with the bouncing/skipping effect; if anything it'll make it worse.
#22 |
#23 |
Just post a picture of what you have.
Jimmy
#24 |
#25 |
I also checked my shock part #. They are 20851 which are monroe 20851,HD shocks. That might be my issue as the shock might be rebounding too quickly, acting like a spring with no load? Does that make sense?
