Old 05-03-2018, 03:12 PM   #1
ChadW
another steering column thread/question
I've been researching the column swap and see lots of people go with a 70s van tilt column to retain the dash key...All the ones i see like this are column shift though...
What can i use for a column swap for to have tilt wheel, dash key and floor shift in a 66 c10...
ChadW is offline   Reply With Quote
Old 05-03-2018, 03:15 PM   #2
oldtrux
oldtrux's Avatar
Re: another steering column thread/question
Ididit
Retrofit specific for our trucks
oldtrux is offline   Reply With Quote
Old 05-03-2018, 03:36 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Ididit has the only ones 'I know of' that are vehicle specific to this series truck.
Old 05-03-2018, 04:58 PM   #4
ChadW
Well...what really constitutes the need to change out the column? I guess my column is ok just doesnt have tilt, but the turn signal lever doesnt seem to work right, just falls down when pushing up etc etc (truck was/is in pieces as its a project) Can they be rebuilt? Any reason to swap a column?
Old 05-03-2018, 10:44 PM   #5
franken
Some like a tilt because the wheel is in a poor position for them. Others because it's a feature. If the wheel is in a good place for you, no need to swap.
You can almost certainly fix what's wrong. Sounds like the TS switch is dead. https://www.google.com/search?q=gm+t...utf-8&oe=utf-8
Stock wheel?
Horn work?
If you hold the TS in the turn position while returning to center does it click indicating it's trying to cancel?
Do the TS work?
If you have 4-ways do they work?
$50 to fix what's there is a lot less than a new/different column for $8 billion, and a van column has gotchas. I swapped a manual truck column into my 72 because the later auto column had the shifter mount. That was back when things were priced lower.
BTW, a truck column is shorter and has the spline right at the end of the tube, while a van column shaft sticks out ~6". 67 and up I think used a collapsible intermediate shaft (to keep drivers from being impaled in a front crash), while 66 and lower a straight shaft all the way down.
Old 05-04-2018, 10:01 AM   #6
vin63
It's Better With Nitro
vin63's Avatar
In my case, installing an Ididit Retro tilt column solved a couple of issues: I was able to push the column back toward the dash a bit since the stock steering wheel/column was too close to me; and, this also helped with the stock steering wheel contacting my legs while driving and getting in/out of the truck.
They can be rebuilt, but I found the benefits of the Ididit column outweigh any cost savings in rebuilding the stock column and still having to deal with the positional issues of the column and steering wheel.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-06-2018, 10:11 PM   #7
andyh1956
Knock the pin outta the shifter, remove shifter handle & epoxy / bondo the hole up. works great!
andyh1956 is offline   Reply With Quote
