Before and After
What size drum and shoes to install on a naked differential?
So the truck I bought that the PO said it needed back brakes, didnt mention that there is nothing but the backing plate and wheel cylinders behind the wheels.
I am trying to get the brakes all set up. I know there are 2 options for brake size. Will it matter what size I go with if I stay consistant with the drums and shoes? Is there a measurement I can take off of the rear end / backing plate / axle to determine what set was on before? Is there a chance I could run something off of a newer (less expencive) model?
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
Re: What size drum and shoes to install on a naked differential?
Place a straight edge across the axle face and measure from that to the backing plate surface where the shoes ride to get a basic shoe width.
Then measure across the backing plate inside of where the drum rides. That's what they will ask, diameter and width after the year make and model.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#3 | |
Before and After
![]() Join Date: Mar 2003
So what is this mysterious axle were talking about
Go disc instead?
