1959 duel master cylinder with power booster
I would like to install a duel master cylinder with a power booster. The start of many questions to come is the transmission crossmember. I have an original 4 speed manual transmission. Do I have to replace the transmission crossmember?
Re: 1959 duel master cylinder with power booster
It will work with the four speed and cross member, just fine plenty of room
for the brake system to fit. ![]() |
I'm glad you posted this, I am wanting to do the same thing on my 59 with the original 235 and 3 speed transmission. Will it also fit my application as well?
I was wondering which company to use?
I got mine from Brothers,fit very well, easy install. Plenty of vendors have these units look for direct bolt on.
I think the three speed has a problem with linkage being in the way. Just look and see if you have clearance of about 8 inches from the frame out ,where old master cylinder is mounted. If you have the clearance it will fit. ![]() Last edited by sack54; 05-06-2018 at 07:26 AM. Reason: more info. |
If you are tight for room just use updated two chamber master cylinder no booster and add one of these to your system.
http://www.ecihotrodbrakes.com/brake...ultiplier.html Makes old brake systems work great ,take no room to install ![]() |
If I install the 2 chamber master cylinder and front disc kit without the vacuum booster will I see a noticeable difference over the stick drum set up? Or even just the front disc kit on the original master cylinder.
The stock master cylinder has one chamber .If you had a brake line let go no brakes
With the newer master two port if you were to loose a brake you still have other port to stop vehicle . front and rear are separated for this reason . Trucks and cars had disc brakes without power boosters. Better with booster and equalizer valve. ![]() |
Look for a unit like this will work fine. drums rear disc front
if you can mount a power steering pump, or already have power steering, you may also consider a hydroboost system. smaller system, size wise. there are some hydraulic lines to run. check ogre's build for a few pics of how it would look. kim57 also has one in his build. there may be others as well if interested. can use a junkyard booster with a few mods.
make sure to get the master cylinder to match your system, disc front/drum rear or whatever, disc front/disc rear or whatever. the master cylinders for drum brakes may have a residual valve built in and that may screw up the operation if not removed/installed for your set up. |
Do I need residual valves as well and if so would I need them with the balance valve?
here is a little explanation of a brake system with some good pointers onhow stuff works and what stuff does.
http://www.hotrod.com/articles/brake...ot-rod-basics/ |
#15 |
and a pic of what a hydroboost looks like
https://www.performanceonline.com/19...e-Booster-Kit/ |
#16 |
and a couple of builds with the hydroboost on 55-59 chevy
#17 |
look at orrieg's build, he remote mounted the booster/mc behind the x-member with a rod
as dsraven mentioned hydroboost is very effective at braking, i run one on my 58 truk
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#18 |
Called cpp yesterday and they said it wouldn't fit with the 4 speed manual because of the clutch linkage. They said the master cylinder alone would fit.
#19 |
call Brothers I called ordered and installed the whole unit ,no problems bolted right in. Plenty of room .
If you want I'll get a picture of mine in place ![]() |
#20 |
cpp also told me that their setup wouldn't fir in my '49 with an m21. said no room for the shift linkage. bought one just to try it & it fit with plenty of room.
#21 |
It would be great if you can send me a picture. thanks so much...Anthony
#22 |
hope these pictures hep you out
#23 |
Dual diaphragm boosters have a smaller outside diameter, there seems to be plenty of room
#24 |
Thanks Guys, I spoke to Sack54 and he guided me in the right direction.Ordered set up for the power brakes. I wanted all original but safety first.
#25 |
Mine fit fine with the stock 3 speed setup.
