Old 05-06-2018, 07:10 AM   #1
bennylava
bennylava's Avatar
Fix some of the understeer?
As I'm sure most of you are aware, these truck suffer from some degree of understeer. I'd just like to know if anyone here ever did anything to correct it. About the only thing I can think of, would be changing the gear ratios in the steering box. But maybe someone else has some other ideas.
bennylava is offline   Reply With Quote
Old 05-06-2018, 02:48 PM   #2
kipps
Re: Fix some of the understeer?
A quick google search says front-heavy vehicles tend to understeer. Possibly a rear fuel tank instead of side-saddle tanks? Move the battery to the bed? Use a fiberglass doghouse? Maybe a Corvette transaxle?
Personally, I don't care. Mine's a 3/4 ton 4wd work truck. I'm just throwin' out a few hair-brained ideas.
Edit to add: steering ratio should have nothing to do with under or over steer. I'm pretty sure it's all about tires, weight distribution, and suspension(including frame flex).
kipps is offline   Reply With Quote
Old 05-06-2018, 05:05 PM   #3
Kudzupatch
Kudzupatch's Avatar
Steering box change will not have any effect on handling because it will not change suspension geometry which is what you need to change.
To change the handling your are going to have to change the suspension. Best bang for the buck is sway bars. Lot of things you can change and you spend as much money as want improving handling.
Kudzupatch is offline   Reply With Quote
Old 05-07-2018, 10:03 AM   #4
SCOTI
SCOTI's Avatar
Factory alignment specs favor under-steer as a safety net.
C10's usually call for +.5 camber w/o wearing the tires. I do -.5 camber. It makes a difference. Lowering the center of gravity & a 1.25" sway-bar also helps.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-07-2018, 07:24 PM   #5
cadillac_al
That's why everybody needs 2 vehicles. A car to race around with and a truck to haul stuff.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-07-2018, 10:20 PM   #6
SCOTI
SCOTI's Avatar
I zip around corners just fine & can stll haul whatever in my CC dually. Just because the factory didn't optimize their potential doesn't mean we can't. My dually drives/rides like a much smaller truck.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-08-2018, 09:36 AM   #7
Kudzupatch
Kudzupatch's Avatar
My Suburban is lowered with front and rear sway bars. Other than lowering it, the suspension is pretty stock except for urethane sway bar bushings. It will surprise you how well it corners and how flat it stays. When you push it till it slips, it understeers, that is just normal for most of them.
Old 05-23-2018, 05:20 PM   #8
Bluestep
A good rear sway bar and rebound clips on the leaf springs will help a lot.
I put a sway bar off of a '95 Nissan Pathfinder on my '74 Chevy 1/2 ton along with new rebound clips . This made the biggest improvement in the handling.
The very first thing to do is to check for "play" or movement in all the suspension (front and rear) and steering linkage parts and repair as needed. Shocks and tires affect handling and ride comfort a great deal. I think for the most part the suspensions on these pickups are pretty good other than the missing sway bar(s), which is common for most manufacturers. The current trend of spending a fortune to replace all the suspension with after market parts is really unnecessary if your goal is to have a good handling pickup. I love the way my pickup handles now after these and other changes. I like tossing it around the roundabouts near my house.
Bluestep is offline   Reply With Quote
Old 05-23-2018, 10:58 PM   #9
Ziegelsteinfaust
On another forum there was a make in handle thread, and I did everything it mentioned on my C20. Before it became my K20.
1 move the lower a arm forward 3/4 to 1 inch forward. This helps with camber gain in corners helping push the truck out of the corner.
2 you can lower the upper A arm down 1/2 inch. I forgot what this does.
Then the obvious like drop springs, spindles, and good shocks.
Ziegelsteinfaust is offline   Reply With Quote
Old 05-24-2018, 11:15 AM   #10
SCOTI
SCOTI's Avatar
#1 Improves caster. These trucks were limited in their caster range.
#2 Improves the camber curve. It's similar to the 'Gulstrand mod' many early f-body owners did.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-25-2018, 09:42 PM   #11
jkk
jkk's Avatar
Put front and rear sway bars on it will make a diffrence
jkk is offline   Reply With Quote
