#201 |
![]() Join Date: Mar 2011
Re: The Doc & Kim 69 build
just saw this no real updates ...purchased the brake lines from Inline tube got to get at it soon will post some pics soon thanks for looking and nice comment
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#202 |
no real progress all summer I dropped the motor and trans in the frame this weekend . 1. to measure drive shaft 2. get it out of the other garage ...maybe mock up the exhaust....cab sits in waiting
#203 |
finally stole some time mocked up the front brake lines InLine tube makes that a simple proposition rears are basically going to come together after i get a few brakets and clamps from CPP cut and flare the pre-bent lines to fit the rear disc.conversion
#204 |
Looks like it’s going to be a serious handler with those suspension mods and nice work on the brake lines
#205 |
Nice start on the truck..... I like the PC setup...
#206 |
thank you Dave, lots of help from this board on studying others builds and techniques .. wish I had more time ...not complaining , I am past retirement age and could but Im having fun with the work I do, people I work with, and the $s r good too hope to make more progress in Feb.
#207 |
thanks Andy ..the expirence like anything else more you PC better you get, its fun and relatively inexpensive compared to sending the small parts to a Pro at least thats what I have found here in Jersey I have a bunch of parts that are prepped just haven’t found the time to get to them ....but stay tuned
#208 |
some progress DS cleaned up and installed, shocks mocked and today started on the exhaust kit . Im going to have to fab a bracket, something to hold the mounts to the after market shock cross member modify the H- pipe so it will run thru the trailing arm C-member. Anybody that has used this kit( Flowmaster american thunder )have pictures they can share?
#209 |
I tried the "Pypes" 2.5" duals kit designed for our trucks and had to return it because I have the same trailing arm crossmember. These 2 systems (Flo-Master and Pypes) are intended to run underneath the the factory trailing arm crossmember. The only solution I could find was to buy a builders kit and route it where I needed it to go, not too bad a job and actually cheaper as well. If I can find some pics I'll PM them to you.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#210 | |
#211 |
finally... tires rallies trim and centers......
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 02-20-2019 at 08:30 PM. Reason: pics |
#212 |
Jesse, nicely done on the ralleyes, truck is starting to come together
#213 |
This is what I did to get around the problem of the Pypes 2.5" kit not going through the crossmember. It is a builders kit from Summit, and it was about half the price of the kit that as "designed" for the truck. Not raggin' on the kit at all, it just didn't work with a lowered truck.
#214 |
thanks Jim to you on those trim rings they are stellar
#215 | |
![]() ![]() thanks again Jess
#216 |
I made it. It looks good but needs more structure added to it. It kinda lets the tail of the transmission bounce too much. I plan on getting it fixed soon.
#217 |
nice work on that c-member ....get that patent going I think you got something there...I can see it now Cornerstone Crossmembers
#218 |
How and what did you use to clean them up? They didn't look that good in my basement
#219 |
little elbow grease and this.........they been hanging on my wall for 2+ years since I last saw you
#220 |
Thanks for the info., vanilla scented too. When the snow stops flying I'll have to stop over, the Camaro doesn't like salt
#221 |
live learn and pay for my mistakes but thanks to Grumpy Im comfy ( that rhymes ) with the drive shaft position of the yoke what a difference an inch makes
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 04-01-2019 at 11:04 PM. Reason: MORE |
#222 |
Looking good sir!
#223 | |
#224 |
today we used 3/4 inch conduit to make the angles we need in the bends for the rest of the exhaust system....next problem is finding someone with a Mandral to bend stainless my local shop recommended a shop in Linden NJ hope he will do it for me his receptionist said to email him I will with the pictures. I went to his web site looks like he does some highend work and has participated in SEMA in the past ill see if i can get his attention
#225 |
crickets, all I hear are crickets....
any thing new? rolling chassis looks great
