Okay to use aluminum hard lines for transmission to radiator?
I was thinking about making my own hard lines with AN fittings. Any thoughts?
Re: Okay to use aluminum hard lines for transmission to radiator?
I wouldn't. Aluminum is too soft and can be cracked or punctured too easily. It also fatigues much easier and quicker than steel.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
#4 | |
I wouldn't use aluminum again. And, can't bend small steel lines tight enough (at least I can't...). Just for what it's worth... |
Thanks for the input guys. I hear what you're saying about the aluminum but I have a couple of questions to further clarify. How much pressure could the fluid possibly be under? The Silverado I pulled the motor/tranny from had aluminum lines if I recall correctly. Also, airplanes use aluminum lines in the hydraulic systems, and thet operate at 3200 psi. It probably has a lot to do with the grade of aluminum. Now fatigue is another issue entirely. I could see where that might cause problems if allowed to flex much. Which would be easier to flare/ work with, steel or stainless lines? I know stainless is hard to hand bend at these larger sizes.
There's not enough pressure to burst aluminum, but there's no reason not to use steel. It's cheap, fittings are cheap, it's easy to bend and flare, and you can paint it if you're concerned about rust. Stainless is a pain to deal with and, having used it previously, would recommend strongly that you don't go that route.
![]() Join Date: Feb 2004
OEM uses it but as you will notice they usually have a short rubber hose on the end as well as o ring seals that allow for movement.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
