Old 05-10-2018, 01:18 PM   #1
regan56
5 x 4.75" or 5"
so im in the garage a day ago, admiring my handy work on my 56 GMC after i mounted the springs to my rear end and for something to do i measured my bolt spacing. i had all along assumed i had a 5x5" spacing, not even thinking about it until then. turns out i have a 5x4.75" spacing. in teh meantime i have purchased (not expensive) a set of 5x5 GM rallys, that ive yet to pay for and pick up.... well f##k.
so now im in a pickle...
a) buy the rallys, swap out the entire rear end for a 5x5 set (wasnt a huge fan of the 3.08 gears anyway)and larger gears
b) buy teh rallys, swap out the axles for a 5x5 set
c) abort the rallys and stick with the 5x4.75 and find different wheels.
also, i have no front end yet so thats of no consideration..ill get one to match teh back
regan56 is offline   Reply With Quote
Old 05-10-2018, 01:59 PM   #2
mr48chev
mr48chev's Avatar
Re: 5 x 4.75" or 5"
What's the pattern on the front hubs? That should be the deciding factor.
Finding a 5 on 5 rear axle with the right gears that will fit under the truck and not have the tires stick out too far may be the big issue. Most are also going to mean that you have to come up with another driveshaft if you already have one.
A 71/72 GMC 1/2 ton rear would give you 5 on 5 and the least hassle mounting it. It might not be in the way too wide category.
Another choice and probably not expensive might be a rear out of an early 80' full size Buick Electra, Olds 98 or Chev Caprice that had an overdrive trans. I think they had 3.5 or 3.7 gears. You have to make sure and check the bolt pattern and make sure the donor was an overdrive car. The width on those is probably close to spot on but they have a lot of scabs you will have to trim off.
My ongoing truck projects:
Old 05-10-2018, 03:49 PM   #3
joedoh
joedoh's Avatar
Re: 5 x 4.75" or 5"
plenty of wheels available in 5x5 and 5x4.75.
also remember that when you are measuring a 5 lug pattern it is NOT center to center across two lugs, it is center of one to the EDGE of the other. that could be your extra 1/4 inch.
Old 05-10-2018, 04:31 PM   #4
regan56
Re: 5 x 4.75" or 5"
i did measure CtoC so....ya....theres that.....
Old 05-10-2018, 04:42 PM   #5
joedoh
joedoh's Avatar
Re: 5 x 4.75" or 5"
haha sweet. I have done it before, that is experience talking
on the plus side, your new wheels should fit!
Old 05-10-2018, 04:47 PM   #6
MiraclePieCo
MiraclePieCo's Avatar
Re: 5 x 4.75" or 5"
Nice save joedoh!
MiraclePieCo is offline   Reply With Quote
Old 05-10-2018, 05:11 PM   #7
regan56
Re: 5 x 4.75" or 5"
Originally Posted by MiraclePieCo View Post
Nice save joedoh!
yes, nicely done sir...beers on me!
Old 05-10-2018, 06:32 PM   #8
joedoh
joedoh's Avatar
Re: 5 x 4.75" or 5"
woop woop! I am a cheap date too, QuikTrip tea!
Old 05-11-2018, 05:08 PM   #9
my56chevytruck
my56chevytruck's Avatar
Re: 5 x 4.75" or 5"
[QUOTE=joedoh;8258529]plenty of wheels available in 5x5 and 5x4.75.
[/QUOTE
Some of the "internet mechanics" have shown measuring 5 lugs center to center. You're spec on joedoh
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 05-12-2018, 09:20 AM   #10
Driver_WT
Driver_WT's Avatar
Re: 5 x 4.75" or 5"
I learned something new today. Thanks.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 05-12-2018, 11:44 AM   #11
mr48chev
mr48chev's Avatar
Re: 5 x 4.75" or 5"
I cheat I have a couple of bolt pattern checkers. I actually went and checked the diagrams and yep the ones above are correct.
Old 05-12-2018, 12:01 PM   #12
_Ogre
_Ogre's Avatar
Re: 5 x 4.75" or 5"
it's the diameter of the centerline of the pattern
even lugs like 4, 6 and 8 are measured center-center
center to edge on 5 lug patterns is a good approximation
some wheels have both patterns on the hub, like truk wheels from wheels vintiques
shop air compressor timer
Old 05-12-2018, 12:48 PM   #13
Dan in Pasadena
Dan in Pasadena's Avatar
Re: 5 x 4.75" or 5"
^^^ You can get the dual pattern on reproduction Rally wheels so it should be easy for the OP to resolve his dilemma.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 05-13-2018, 12:32 AM   #14
joedoh
joedoh's Avatar
Re: 5 x 4.75" or 5"
I havent seen a lot of dual pattern wheels with 5 on 4.75 and 5 on 5, usually the second pattern with 5 on 4.75 (small chevy) is 5 on 4.5 (small ford)
usually with the dual pattern 5 on 5 wheels (big chevy) the second pattern is 5 on 5.5 (big ford)
Old 05-13-2018, 01:26 AM   #15
Dan in Pasadena
Re: 5 x 4.75" or 5"
Here's a dual pattern one for the OP or anyone else who might come to find this thread later:
https://www.ebay.com/itm/1-17x7-ALUM...oAAOSwa39Uts8V
Old 05-14-2018, 12:48 PM   #16
regan56
Re: 5 x 4.75" or 5"
just an update, just to close the loop on my end. STD GM ralleys fit as i'd hoped. crisis averted!
THX ALL
Old 05-15-2018, 10:07 AM   #17
dsraven
Re: 5 x 4.75" or 5"
just as a side bar, there are easy to download/use or make "lug pattern template tools" that are nothing more than a plastic or paper circle with the holes cut/marked at the different pattern locations. easily made with a school kids compass and protractor kit or download and print off the net for single uses like this.
nice you got the pattern figured out. it may affect the final outcome of what you will use up front I guess.
good luck
Old 05-15-2018, 11:15 AM   #18
regan56
Re: 5 x 4.75" or 5"
good luck
..yes i thought of that. i work in CAD everyday so it would be fairly easy for me to come up with a template.
with regard to teh front end, i called Heidts to find out if they could do a 5*5 M2 (didn't see that option on their website) and they can, for an extra $90USD per hub, so its can be done.
Old 05-15-2018, 04:45 PM   #19
dsraven
Re: 5 x 4.75" or 5"
make sure to get the size of wheel studs to match as well when you order. it would suck to have 2 different sizes on the lug nuts.
Old 05-15-2018, 04:46 PM   #20
regan56
Re: 5 x 4.75" or 5"
..good call, i will make sure i do that. thank you for teh heads up!
