Old 05-15-2018, 07:50 AM   #1
Sadlerracing529
1963 project truck
Hey everyone. Just wanted to introduce my project. I have a 1963 c10 long bed fleetside with a 230 i6 and sm420 4 speed. Truck has been in my family for almost 30 years and has been my grandpa's daily driver up until a year ago.
As far as project goes it will be done in stages.
First stage is going through, making sure everything is up to par to be safe to drive, and a basic small block and different manual trans...t5 maybe? Not sure the best route to go there. Just keeping it pretty simple for now as I'm expecting my first kid this fall, and don't have a place to do the full restoration right now.
Future plans include full restoration, updated suspension front and rear with full disk brakes, and big block. Truck will be lowered on coil overs...not slammed. And I will be making it a short box.
And yes the truck has an 80's bed on it at the moment...my grandpa put it on
Sadlerracing529 is offline   Reply With Quote
Old 05-15-2018, 08:32 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 1963 project truck
Welcome! Looks like a great project with a lot of sentimental value. This forum is a great place to help with your build up. I'm a little partial to '63s.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-15-2018, 08:52 AM   #3
Sadlerracing529
Thank you. I remember playing in this truck when I was a little kid, I Nick named it the beast when I was about 6 years old haha. And yes I find myself partial to the 63's as well
Old 05-15-2018, 01:07 PM   #4
64stpside
I just did a T5 swap on my 64 c10. What a difference, the only thing is 1st gear is a little short (I gotta shift 1/2 way through the intersection if making a turn at a stop light). It has a 1978 305 and had the the 3 speed sag behind it. The swap was much easier than I thought it would be. Try to find a world class T5 as they are a bit stronger. Got mine from a 92 s10. I did the jeep input shaft swap and did lugnutz custom shifter. I had the early bell housing Here's a few links to save for when you do it. lugnutz site is really good. Read everything.....lol.
https://lugnutz65chevystepside.weebl...ter-plate.html
http://www.hotrod.com/articles/1201c...tall-underside
64stpside is offline   Reply With Quote
Old 05-15-2018, 11:44 PM   #5
Captainfab
60-66 Nut
Welcome to the forum
Sounds like you have a good plan. An OD trans is a good choice for these trucks.
Old 05-16-2018, 12:51 PM   #6
Sadlerracing529
Thanks. I'm kind of undecided on the trans right now. I'm thinking either t5 or a Muncie m20 or m21 if I can get my hands on one. Just worried about the strength of the t5. My small block will probably end up at about the 300 ft. Tq. mark, nothing crazy, but I'm pretty sure the t5's are rated for less than that
Old 05-18-2018, 07:59 AM   #7
Sadlerracing529
I have the sm 420 trans behind the 230 i6, Would trans, bellhousing, starter, and flywheel bolt right up to my chevy 350? If so I might throw my stock 350 in this weekend
Old 05-18-2018, 09:35 AM   #8
64stpside
Here's a T5 list, if you get a world class s10 t5, you get a 300ft lb tq rating. You got to find a 92 or 93 to get the s10 world class. Mine is from a 1992
http://www.britishv8.org/articles/bo...t5-id-tags.htm
Old 05-18-2018, 09:50 AM   #9
Sadlerracing529
Thanks 64stpside, good info in there. I probably will end up going t5 in the future. For right now it seems like everything in the truck should bolt to a 350 so I'm thinking of dropping my stock 350 in this weekend. Then do the t5 when I finish my mild 350
Old 05-18-2018, 11:01 AM   #10
Clyde65
Clyde65's Avatar
Welcome!!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-18-2018, 11:38 PM   #11
Captainfab
60-66 Nut
Yes, everything will bolt up to your 350, The same motor mounts and motor mount location. You will want to change the radiator to the V8/HD cooling radiator that sits on top of the frame and right up against the radiator support. If your 350 is a '86 and newer, you will need a different flywheel.
