1971 C10 Steering
My newly acquired 71 has loose steering. It wonders around a lot especially on rough roads and changing lanes. how do I know if it is the steering box or linkage?
Re: 1971 C10 Steering
I am still learning about these.. I just ordered a new one fro mine (leaking). Interested to see what everyone says. My guess it's the box.
![]() Join Date: Mar 2017
Have someone turn the wheel while you check for loose tie rods and play in the steering box.
I would lift the front end and inspect all your steering components. My truck had loose steering when I first picked it up and I attributed it to not being rack and pinion. I hadn’t driven one for about 20 years. When I did some suspension upgrades, I discovered my pitman arm was loose. The nut was only finger tight. It could’ve ended badly for me.
![]() Join Date: Mar 2011
you can also jack up the front end and try to move your tires back & forth while someone looks at the tie rods, center link, idler arm ,and pitman arm for play...let us know what you find
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
![]() Join Date: Feb 2004
Well sir I have been battling this as well. I have every part new even new redhead gear box and it still has more play than I like. Toe out can cause it. I'm actually wondering if the column it self could have play in it? I dont have a rag joint anymore so I know it is not that!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
The wider front tire will grab the ruts and cause it to pull. If it has a manual box, you can loosen the nut and turn the screw in a full turn or so.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
OP.... Looks like your lowered? . Are you on drop springs in front? do you feel like it may also be bump steer contributing to the "loose" feel? Mine was like that until i did drop spindles now it is perfect.
Thanks!
Yes drop springs Thanks!
