Old 05-17-2018, 09:30 PM   #1
SS68
SS68's Avatar
where does one mount the fuel regulator
I'm using a Holley sniper efi intake with the holley rails
aeromotive pump has three ports 1 oulet 2 vent 3 return
aeromotive filter in between pump and rails
also where do I put the return line.
I made a visual for where I'm at. a lot easier for me to understand than reading others threads and builds. appreciate the help
SS68 is offline   Reply With Quote
Old 05-17-2018, 09:52 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: where does one mount the fuel regulator
Return or returnless fuel system
Return still
No Y fitting at the rail, the other end of the rail goes to regulator and then to tank.
Returnless
If your doing a returnless like you have pictured, the regulator goes after the filter before the rail.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 05-17-2018, 10:10 PM   #3
SS68
SS68's Avatar
would you recommend the corvette pump with the built in regulator how restrictive is it? if boost is in the works
Old 05-18-2018, 11:37 AM   #4
davepl
davepl's Avatar
I'm confused... the Holley Sniper has a built in fuel regulator. You CAN set up your own regulated system and just supply it with 58psi but why bother? Just give it raw pump pressure and it has a full internal regulator to deal with it.
Here's mine, one line in and one line out. 3/8 line from pump to Sniper, 3/8 return to tank. No regulators, no Ts, no rails, no nothing. Easy peasy.
The hardest part (and the only hard part, really) is running the return line from throttle body back to tank. If you can swing that part, you're golden. I went all stainless hard line and for the little 4" flex sections I used stainless PTFE lined hose, so there's not an inch of rubber in the entire fuel system!
Your other option is to have the pump feed into the GM regulator/filter you're talking about. Then it has a return line back to the tank also, and the output is 58psi that you run right to the throttle body with no return, capping off the return port.
Make sense? I just did this so ask away... there are no dumb questions.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-18-2018, 02:09 PM   #5
mongocanfly
mongocanfly's Avatar
you've got the aeromotive pump..you wont need a holley pump...
just use a vet filter/reg in line
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-18-2018, 02:13 PM   #6
mongocanfly
dave I think hes running the sniper intake....not the sniper throttle
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-18-2018, 04:11 PM   #7
DLW
If your running "boost" as you mentioned you might, its not a bad idea to run a EFI bypass regulator with a vacuum/boost reference 1:1 ratio, so if need be you can increase fuel pressure with boost. Regulators should go after the fuel rail back to the return port of tank.
DLW is offline   Reply With Quote
Old 05-19-2018, 03:26 PM   #8
SS68
SS68's Avatar
thanks for the help and correct I am running the sniper intake. went ahead and ordered -8 hoses and connectors will post pictures up next weekend installed. thanks for the replies
Old 05-23-2018, 11:52 AM   #9
davepl
davepl's Avatar
OK, that makes sense. When faced with that setup, here's what I wound up doing.
In this case I ran it as follows:
- Pump to Y block splitter
- Each split to back of fuel rail
- From front of each rail to regulator
- Regulator to tank
That's the highest flowing setup you can do, I believe. I did that for my high horsepower setup but you don't have to be that elaborate for a 300hp crate engine, for example!
I've never run the GM integral filter-regulator setup, but have seen it used with success a number of times.
