Old 05-17-2018, 10:54 PM   #1
'65 chevy lover
Taillight wiring diagram 65 C10
Howdy everyone, could someone please point me to a diagram for the taillight wiring for my '65 C10? I'm down to just a few things to do to be done with my truck. I have a new wiring harness from American Autowire and, I have a good idea of how it goes but would like to know for sure before I start so I don't screw it up. I've done search's on the net, but have yet to find what I need. Any help would be greatly appreciated!
'65 chevy lover is offline   Reply With Quote
Old 05-17-2018, 11:12 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Taillight wiring diagram 65 C10
I found this in the FAQ section: http://67-72chevytrucks.com/vboard/s...d.php?t=646002
Wiring diagram for lights: http://67-72chevytrucks.com/vboard/s...d.php?t=629550
Old 05-18-2018, 03:49 PM   #3
DLW
This one post #3
http://67-72chevytrucks.com/vboard/s...d.php?t=509085
This one is of the 67-72 wiring but is probably close if not the same to our vintage. My 66' has reverse lights, the 64 diagram does not show them, but the 67-72 does.
Post 1, you can click the links for a high res and save it.
http://67-72chevytrucks.com/vboard/s...d.php?t=662676
DLW is offline   Reply With Quote
Old 05-18-2018, 07:05 PM   #4
'65 chevy lover
Thanks to ya'll for the replies. I didn't do a good job of Describing what I need. I should have said routing instead of diagram. What I'm needing is the actual routing of the harness, especially where it leaves the cab. A friend of mine said a plug inside the cab, exits thru the firewall, and the wiring harness attaches there and then runs under the cab to the back from there. I thought the wiring went from under the dash and exited thru a hole in the floor on the driver's side toward the back of the cab and then runs to the back.
Old 05-19-2018, 11:28 PM   #5
DLW
I think this should help with the firewall connection:
The rest just follows the driver side inner frame rail in the stock wiring harness clips.
Old 05-20-2018, 08:07 PM   #6
'65 chevy lover
This confirms exactly what my friend said. It also clears up questions I had about some other holes in the firewall. I never should have questioned my friend. He's a pretty smart dude! Thanks for your post.
Old 05-20-2018, 08:30 PM   #7
The Rocknrod
Moderator
Wire routes are shown in the truck assembly manual that are for sale in many places.
