Old 05-19-2018, 04:19 PM   #1
Dodge68charger
Brake Caliper Mounting. Cpp Brackets Question
Is The Distance Supposed To Be Even On Both Sides? I Cant Get The Pads In on One Side Because Theres Not Enough Room. I am Using Cpp Drop Spindles and Brackets With Stock Calipers.. Thanks
Dodge68charger is offline   Reply With Quote
Old 05-19-2018, 05:12 PM   #2
SeanB242
SeanB242's Avatar
Re: Brake Caliper Mounting. Cpp Brackets Question
Not sure about that one. The CPP kit I just put on don’t look like that one. Is the back of your rotor hitting the spindle? Or is that just the angle of the picture?
SeanB242 is offline   Reply With Quote
Old 05-19-2018, 08:00 PM   #3
Dodge68charger
Just The Angle Of The Picture
Old 05-20-2018, 01:17 AM   #4
Dodge68charger
The Spindles I Got Are For a 87 suburban. I Swapped Front Ends. Just Not Ste If The Calipers Supposed To Be Centered to The Rotor.
I did some Research and My Brackets Are on Backwards
Old 05-22-2018, 07:56 AM   #5
Artofdeath
Artofdeath's Avatar
Looks to me like the caliper should be on the oustide of the gold bracket.
Artofdeath is offline   Reply With Quote
Old 05-22-2018, 11:24 AM   #6
demian5
demian5's Avatar
It is...
How the heck will the brackets on backwards fix this? Unless it mounts the bracket on the other side of the spindle mounting points (which it cannot).
And when you saw "stock" calipers, do you mean for the truck this is on, or for the 87 suburban?
Post pictures of what was wrong.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-22-2018, 01:57 PM   #7
Artofdeath
Artofdeath's Avatar
ikr, this is one of those that has been bugging me, while falling asleep. Hopefully OP will show us the fix.
Old 05-22-2018, 06:57 PM   #8
Jason Banks
Jason Banks's Avatar
OP is back with a new thread and new pictures:
http://67-72chevytrucks.com/vboard/s...d.php?t=764282
Jason Banks is online now   Reply With Quote
Old 05-22-2018, 09:11 PM   #9
Dodge68charger
Hey Guys If You Notice The Brackets Have a Bend In Them.. The Instructions i Found on The Internet Said The Bend In Them Should be pointed Outwards. Not Inwards Like i Had Them.. Now That I Flipped The Bracket The Calipers Are Centered to The Rotor.
