Old 05-20-2018, 12:11 PM   #1
Macdaddy1
2006 5.3 vortec swap advice
So the project that I am currently working on is a 1965 C10 that came with a 1965 327 SBC out of a corvette. To make a long story short after assembling the engine components carb, belts pullies etc. and running it for about 10-15 minutes over a period of several weeks to test fit and such I now have a whole lot of coolant in the engine. So I am thinking of starting over. I have acces locally to a 2006 5.3 chevy vortec engine out of a silverado with 89K miles with no accessories or wiring that i am contemplating turning into a carb ureted LS swap . How hard and what cost to purchase all of the accessories to make this a carburated 5.3 for my truck. I have read as much as I can on many forums and have some idea but wanted to ask the experts for some real world advice.
Macdaddy1 is offline   Reply With Quote
Old 05-20-2018, 09:40 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 2006 5.3 vortec swap advice
I've never carbd a LS and never will....
that is a good low mileage LS but would have to be cheap with no accessories...having to buy everything needed would make it costly
I would keep the ls injected or fix the 327 if possible...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-20-2018, 10:40 PM   #3
Wildkarde
While I'm not really a fan of the carburated LSes I know some people just love thier carbs. It's not very difficult, but will be more expensive than keeping the fuel injection, especially if you leave the engine internals stock and don't need a full dyno tune.
The carb intakes are pretty expensive, and you need either a spark control box that takes the ls cam/crank sensors and runs the ls coils, or a bolt on distributor. Niether are particularyl cheap.
Wildkarde is offline   Reply With Quote
Old 05-21-2018, 02:24 AM   #4
ls1nova71
ls1nova71's Avatar
I agree with the others, keep the EFI, that's one of the best parts about an LS. As for a harness and accessories, they're dirt cheap for a truck engine and the pick n pulls around here anyway are full of them.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-21-2018, 10:21 AM   #5
Macdaddy1
Ok i am convinced find the LS swap with EFI. Thanks to all for your help and advice. This is what makes this forum exceptional.
Old 05-21-2018, 12:27 PM   #6
Clyde65
Clyde65's Avatar
I would fix the SBC, the incidentals and accessories will get pricey when you go LS
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-23-2018, 07:13 PM   #7
Macdaddy1
Just pulled the heads on my 327 and the block is cracked on both sides so it looks like I will be trying to source a low mileage 5.3 to swap.
Old 05-23-2018, 07:27 PM   #8
mongocanfly
good idea but id find a complete LS to do your swap...be sure to get everything you need from the same donor...itll make life easier
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-23-2018, 07:30 PM   #9
Macdaddy1
Thanks Greg i am currently researching that now.
Old 05-24-2018, 06:54 PM   #10
Macdaddy1
I just bit the bullet and purchased a 2005 5.3 LS with 86K miles and every option I could think of including the radiator and air filter system to swap into my 65 C10. I will post some pics when it comes in next week. I have learned alot of valuable lessons so far both financially and psychologically but that is what adventures are for. Will update on progress as the experiment continues.
Old 05-24-2018, 09:41 PM   #11
mongocanfly
sweet... did you get trans also?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-24-2018, 09:47 PM   #12
Macdaddy1
Already had a Tremec TKO 500 5 speed overdrive transmission.
Old 05-24-2018, 09:48 PM   #13
Macdaddy1
Mongocanfly
Greg will the standard oil pan that comes with these 5.3's fit into our trucks or do you need to change them out to a shallower oil Pan?
Old 05-24-2018, 10:02 PM   #14
mongocanfly
im not sure on a 65...maybe someone else will chime in....is your truck lowered? that plays into it as well......on my swap the stock LS pan fit perfect...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-24-2018, 10:44 PM   #15
Wildkarde
From a buddies experience, it will fit just fine in terms of clearing everything, but will hang 2.5-3 inches below the crossmember. Whether this is too low for you or not depends on how low you have the truck.
Old 05-24-2018, 10:50 PM   #16
Macdaddy1
Keeping mine standard height so 2-3 inches would be fine with me
