01-05-2018, 02:25 AM | #301 |
Cluster King
Re: Volt Gauge Conversion Kits
PM me your address. Sorry for the delayed response, super busy.
Thank you, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
01-12-2018, 03:30 PM | #302 |
I was under the impression this was going to be a "how to" thread obviously it is not. I already purchased an 87 cluster to swap the gauges but am unclear as to exactly what I need to do. Is that something you can help me with? How much if I sent you both gauges and the tin?
Eric 70 CST10 long bed in pieces also factory air and cruise(the project) 18 Silverado crew cab 5.3 4x4 My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=402166 |
01-13-2018, 01:01 AM | #303 | |
Cluster King
Thank you, Tom
01-17-2018, 12:41 PM | #304 |
01-20-2018, 04:15 PM | #305 |
Cluster King
02-15-2018, 03:44 PM | #306 |
PM sent.
02-15-2018, 10:04 PM | #307 |
Cluster King
02-21-2018, 08:21 AM | #308 |
PM sent
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
03-06-2018, 10:58 PM | #309 |
Cluster King
Your conversion is on the way Mr. Should see it on Thursday.
Thank you again, Tom
05-03-2018, 01:00 AM | #310 |
70+ ( Old Skool Club )
Tom I installed one of your gauges last summer. I've seen this pictured reading quite a few times on the gauge and sometime sits just past the 13. Is this where it should be? My alternator and battery are new..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
05-20-2018, 03:33 PM | #311 | |
Cluster King
Hi Greg, Very sorry for the delay. If you have a volt meter on the battery while running, you should get say 14.5 or so volts. That would be with a good alternator output at idle. I use a 12 v battery charger set on 10 amps which gives me about 12.5 volts and that is where I set the needle. It is possible the needle slipped or I was in a brain fart mode that day and placed it wrong. What I see in your photo should be about 15.5 which seems a little high. Did you check it at the battery? Make sure your regulator is not sticking and causing an over charge condition. If you believe that the volt gauge conversion is in accurate, you can send it back to me for an adjustment or I can send you just the gauge that is set up correctly and you can just swap it. Let me know what you would like to do. I will accommodate you and make this right. By the way, no charge to you. Thank you, Tom
05-20-2018, 03:41 PM | #312 |
Cluster King
Hello all,
I have 2 volt gauge conversions ready for sale if interested. They are $100.00 plus shipping which is $15.00 within CON US. Please inquire if not in the CON US for shipping quote. Thank you for the interest, Tom
05-20-2018, 05:01 PM | #313 | |
05-20-2018, 05:10 PM | #314 | |
Cluster King
Take care, Tom
05-20-2018, 11:33 PM | #315 |
Hard to find good customer service like this these days Tom .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
08-18-2018, 02:05 PM | #316 |
Hi Tom,
Just found this thread while searching for something completely different 😊 Anyway, I wanted to know if you still sell these conversion kits? If so, could you give me an estimate on shipping to the Netherlands? Thanks in advance.
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb 1974 Chevy Camaro Z28 (Original) ------------------------- Capelle a/d IJssel, The Netherlands |
08-18-2018, 04:43 PM | #317 | |
Cluster King
08-18-2018, 04:57 PM | #318 |
Hi Tom,
PM sent. Thank you. 👍
08-18-2018, 11:23 PM | #319 |
Active Member
Sent you a PM tbone
David Larsen 1970 Chevrolet C-10 |
09-29-2018, 04:04 PM | #320 |
Cluster King
I have this volt gauge conversion ready to sell.
It will come with the wiring and instructions to install. $100.00 or $115.00 shipped in med flat rate box with in CON US Outside of CON US, I can quote shipping. More kits will be done soon. Waiting for supplies. Thank you , Tom
10-15-2018, 03:00 AM | #321 |
Hi Tom, I will contact you tomorrow to purchase the gauge kit shown above.
Thanks. Blake |
10-15-2018, 04:21 PM | #322 |
Email sent
Blake |
10-15-2018, 11:31 PM | #323 |
Cluster King
Thank you Blake,
I appreciate your business, Tom
10-26-2018, 10:20 AM | #324 |
instead of running a hot leg between the temp and volt gauge could I leave part of my circuit board in place and tape the other part back?
10-27-2018, 12:27 AM | #325 |
Cluster King
[QUOTE=Stephen717;8372064]instead of running a hot leg between the temp and volt gauge could I leave part of my circuit board in place and tape the other part back?[/QUOTE
If you are referring to the amp gauge portion of the circuit board, they are both live. If you trace it back to the connector, you could actually wire your hot into the number one or twelve location on the connector. For the other side, that does not get used by the volt gauge. If you have amp gauge wiring correctly, either number one or twelve can be de pinned so no power passes through. That way you can wire the volt gauge with the circuit board. You can run power to the volt gauge by any means you feel acceptable for your purpose. As long as it has battery voltage an ground, it will work. One reason I like to tag off the temp gauge is for trouble shooting. If the user has a failure of a volt gauge, the question is does the temp gauge and fuel gauge still work. They all share power. if they all fail, then it is a different approach to diagnose. I provide everything needed to swap this into your truck and have a source to wire it. Hope this helps, Tom
