High Low Horn question
I have a pair of high low horns laying around. My truck is a 68 so it doesn’t have the option for both horns. My question is what do I need to do wiring wise to use both of these. My current harness only has the 1 green wire. Do I need to splice in a jumper wire to the other horn off this green wire? If not can I use just 1 of these horns and does it matter which one?
![]() Join Date: Dec 2012
Re: High Low Horn question
I've thought of doing this on my '68 as well. I don't see why splicing a jumper into the green wire wouldn't work. Not sure what the bracket would be to mount both, though - the one thing I would have to figure out..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
![]() Join Date: Feb 2016
Here is a photo of my 67 dual horn set up. It uses a common factory jumper wire and plug to hook the two together. If you look close on the bottom horn you will see it. I didn't install them but I have seen the jumper on other GM vehicles.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Nice I’ll give that a try. Also noticing my horn brackets are shapped a little different. Instead of having a L at the end mine are just straight. Either way I think I can make it work. Thanks for the photos.
![]() Join Date: May 2010
Here's a picture of a factory jumper wire itself.
I’ve noticed some core supports are pre drilled for the dual horns others not, I located a set of duals with jumper but my gmc core is not drilled for the second horn.
71 C-20 07 Magnum RT AWD |
#7 | |
Here's picture of my current core support from a '71 or '72 showing the mounting positions for the 2 horns. Also note that my '69 still had the washer bottle on the core support. Most later '69s I've seen had them relocated to the fender. |
#8 | |
Who Changed This?
![]() Join Date: Jan 2013
I found the dual horn wiring harness on the Lectric Limited website for $20
My GMC is a 71, no provision for second horn. The dual horns I located where from a 69 C20, even listed on spid.
