Switched circuit for drl's
Hello fellow C-10ers
i am upgrading my headlights to LED' Headlamps from JWSpeaker. The ones i have chosen have DRL's built into them. I would like to have the DRL's to function like DRL's, ie: only on when the ignition switch is on and off when the switch is off. can someone point out to me how to accomplish that? I have also wired the truck to not have the voltage regulator, (new internal regulated alternator), being that i still have the plug for the voltage regulator could i incorporate the drl's into that, so basically my question is, is one of the wires from that connector switched? (please don't kill me for asking such a question about the voltage regulator connector) If someone could give me a right way. i also have a new front harness i'm goona put in with the LED headlights. thanks and please be kind i'm good mechanically not electrically. ![]() |
Who Changed This?
![]() Join Date: Jan 2013
Re: Switched circuit for drl's
What are DRLs?
Daytime running lights
72 C10 lwb fleetside -stock 350/350 combo |
Use the pink wire from the ignition switch to activate a relay.
yes
![]() Join Date: Feb 2004
Correct. Just wire a relay to the drl side and use the pink wire , or any othe ign wire that may be close to fire the relay. I might add, for anyone wanting to do something like this ...here is a link for a good setup at a great price. He will make the wires as long as you need and it's all top notch and water tight.
Look at this on eBay https://rover.ebay.com/rover/0/0/0?m...2F301092476616
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
