#651 |
Re: What did you do to your truck today part IV
Installed rear sway bar after work yesterday. I removed it from a '96 Suburban my uncle was scrapping so I figured I'd try it just for giggles. I didn't expect much improvement from it but I have to admit, I'm impressed with the results.
#652 |
I thought that was a Lagunitas, never seen that one before. My other hobby is brewing... and drinking beer.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
#653 |
I'm retiring in Feb. '19 My new hobby will be religious chemistry, turning wine and into water.......
http://s1299.photobucket.com/user/jb...23904108567829 |
#654 |
![]() Join Date: Jan 2017
thats funny truck guys into same thing
#655 |
![]() ![]() ![]() Join Date: Jan 2018
Started prepping some parts for paint over the past couple days, and got some parts to get the engine back together. Hoping to make at least the Atlanta stop of Power Tour this year. Going to shoot some color in the next couple of days hopefully.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#656 |
![]() Join Date: Nov 2015
Prepped the bed for Upol Raptor Liner. I have a beat up steel bed floor from a '71 c10 and this should make it look so much better!
#657 |
From the seat to the engine bay.
Installed the Clifford intake, 2 barrel Holley and Langdon headers. Tomorrow I need to visit the guy at the hydrolic shop, who is going to make up some braided hoses for the intake water jacket. Then to Meineke to do the exhaust. I also have the lower thermostat housing, that's in the photo on the seat, to install. It has two holes on the sending unit side so I can plumb the hot water from there. |
#658 |
Sweet!
#659 |
chased speedo nut back up to top end of cable after removing/re-installing new mat
![]() cleaned and lubed both side vents and glove box latch.. drank copious amounts of beer and cleaned off some benches of small parts today ![]()
I started out with nothing - and I still have most of it |
#660 |
Finally sprayed the Upol Raptor bed liner. I sanded, cleaned, and sprayed Upol's Acid primer #8 prior to laying it down. It was super easy and looks great. It will be a week or so before I can test it out, though.
The bed floor is from a '71, I believe, and beat to hell, but it was free. I do not like the wood beds. |
#661 |
Installed fiberglass smooth dash. No switches, no nothing except 6 gauges. Will repaint to match console later.
#662 |
Moderator
![]() ![]() Join Date: Aug 2011
You can't just drop that and leave. Who made the dash? Where did you buy it?
#663 |
![]() Join Date: Apr 2011
This past Sunday we got all the wiring finished. Headlight, taillight and signals working. Only a few more things!
#664 |
![]() Join Date: Aug 2004
Small update but big result soon...
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#665 |
![]() Join Date: Feb 2014
Are you chrome plating your vent balls or are you painting them
#666 |
Chrome! They are done...just gotta get the man paid!!
#667 |
My center ones were chrome when I got them from Jim But he had stopped having them platedWhen I bought my side vents let us know how yours turned out and who you had do them
#668 |
Will do!
#669 |
Here's a couple pics.
#670 |
replaced my door hinge pins. I can tell they been in there for 54 years. sprayed with pb blaster the other day. ended up using a saws all to get the hinge apart. broke out the torch to heat the remaining top part of hinge and drove them out. turned into quite the project
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
#671 |
Got cab corner bodywork finished on pass. Side,and inner fender and front fender bodywork finished,driver's side cab corner next,then doors,nice week off ahead!
#672 |
Over the past few days, I've been working hard to get Frankentruck ready to make the Georgia stop of Hot Rod Power Tour. Decided to only paint the parts that were easy to clean up since I'm under a tight schedule lol. The mismatched paint is key to sticking with the theme of being pieced together. Routed the plug wires (yes, those are zip tie wire separators that work great) and finished assembling everything I could before dropping the engine in last night. Today, my buddy and I dropped the engine back in the truck.
#673 |
BK Built
Well today I towed my new one home.
#674 |
More parts!!
And the glass is in and mirrors on..
#675 |
I know it's a minor thing, but I changed the front corner hood bumpers to new rubber, (old ones were hard). And I installed the center hood bumpers (small round ones) none of the trucks I've had, had these. The rear hood bumpers pads are still in good condition. I got the full six piece set front Classic Parts for $5.95.
