Old 05-24-2018, 12:41 PM   #1
WilliamFd55
Exhaust question?
I plan on running 2.5" Duel exhaust into one 5" tip going through the body. Should I make the longer run a larger diameter? I'm thinking about it like fire hose friction loss. Longer run/ Less restriction. Not sure if both exhaust runs needs to be the same to balance the system? Or am I overthinking it?
Thanks,
William
WilliamFd55 is offline   Reply With Quote
Old 05-25-2018, 10:40 AM   #2
SunSoaked
SunSoaked's Avatar
Re: Exhaust question?
Over thinking it. Unlike liquid in a fire hose, exhaust gases change volume based on temp. As the gas leaves the engine it begins to cool and thus lose volume. In your case, it won't make a difference. 2.5 inch pipes are plenty big for one bank of any SB.
SunSoaked is offline   Reply With Quote
Old 05-25-2018, 12:36 PM   #3
WilliamFd55
Thank you for the info....
