#1551 | |
Re: How to: Ruin a perfectly good C10
If only you have some extra dropped C10 parts ![]()
#1552 |
![]() Join Date: Feb 2011
Photoshop look is really cool....gotta make 'er happen. ...just saying!
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#1553 | ||
A guy with a truck
I know, right?! I was on the fence pre-chop. Now I’m sold
All night long! 4wd rides like poop. And unlike the highlander, I don’t have to feel guilty about cutting this one up ![]() I’m with you. Stealing your wheel idea, too. Happy with your VN515s? May be too late for both of those things... Quote:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#1554 | |
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#1555 |
A guy with a truck
Blazer thread here: How To: Ruin a Perfectly Good 4wd
#1556 |
Nice work
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
#1557 |
A guy with a truck
Thanks! Got a little more work in tonight. Finished roughing-in the body work on the firewall and laid a coat of epoxy primer to protect it while I finish mock-up. Next up, stabbing the drivetrain
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 02-06-2018 at 01:29 AM. |
#1558 |
Looks B-E-A-Utimus!
#1559 |
Don't let this one slip through the cracks now that you've got a blazer build going. I want to see this one finished!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#1560 |
A guy with a truck
Thanks! It’s pretty decent; will fine tune it later
Yeah, we’ll see how quickly that one can get neutered. It’s using a separate budget, but potentially borrowing a few parts from the truck... I’ll try to keep them both moving, but the Blazer should be simple in comparison
#1561 |
SHOULD being the key word there....
#1562 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Looks good...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#1563 |
Still Learning
Awesome work on the firewall Chris!
#1564 |
A guy with a truck
Thanks, I’m sure I’ll need it
Thanks a lot! Much appreciated. Still needs some love, but the overall idea is there
#1565 |
A guy with a truck
I picked up a somewhat questionable 4L60E locally, which allows me to use the 700R4 in the Blazer. It also gives me the opportunity to mock-up the drivetrain, which showed me a few things right off the bat: 1) the driver header fits like a dream, 2) the passenger header will not fit at all, 3) the a/c compressor will not mount low like I wanted, and 4) this looks badass
#1566 |
![]() Join Date: Jul 2012
Yep, it does look good!
Does ac compressor get into the engine mount? Or too tight in the frame? |
#1567 | |
A guy with a truck
![]() I’m thinking I may get the passenger header to work by cutting off and re-fitting the head flange. It fits great, other than hitting the coil over mount...
#1568 |
Looks good Chris!
#1569 |
![]() Join Date: Dec 2006
Looking good Chris, I was going to ask what the problem was with the passenger side header but you answered it already! You plan on trying to modify it or are you going to go with something else? These are the speedway engineering headers, correct? How’s the clearance look with the steering shaft on the driver side header?
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#1570 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#1571 |
I'm running the dirty dingo low compressor mount with my SD7 compressor. Plenty of compressor for a single cab. Just sayin'
Oh, and I'm not sure about the dropmember, but the Doug Thorley Tri-Y headers for LS swaps fit great in my 71.
#1572 | ||
A guy with a truck
Thanks, one step forward, two steps back
The manifolds do fit well, but hard to beat the torque kick you get with long tubes Quote:
I’m also looking at other header options, the DTs are nice. Gonna chew on this for a bit
#1573 |
I have some info on the Holley low mount in this thread, it's another option.
http://67-72chevytrucks.com/vboard/s...d.php?t=738296 |
#1574 |
A guy with a truck
Sometimes you just gotta say screw it and start cutting
#1575 |
A guy with a truck
Hung some body parts and set her on the ground. I foresee potential problems with speed bumps
