05-28-2018, 02:06 PM | #1 |
Tach disassembly
I’m having trouble disassembling my factory tach so I can see if I can Bead blast the metal. For the life of me I cannot figure out how to remove these nuts on the back. I do not want to destroy these plastic rings which the nuts are in there is just not enough room to use a socket or wrench. If anyone has tips I appreciate it. Thanks
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
05-28-2018, 02:14 PM | #2 |
Re: Tach disassembly
You could try a nut driver and if it is too thick you can sacrifice it by grinding the outer down till it fits inside of the plastic. It looks like the nuts are rusty on the flats so you may have to scrape on those with a real small screw driver. It probably takes a 5/16" socket
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
05-28-2018, 02:20 PM | #3 |
I was thinking about grinding down one of my nut drivers but it is very thin at the points of the nuts. I was hoping there is a alternative but I’m thinking I’ll have to go this way. I would destroy them but not sure where to get replacements.
05-28-2018, 02:58 PM | #4 |
I've just used a good set of small needle nose pliers. The nuts aren't torqued so just turn out enough to get a socket on them.
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
05-28-2018, 03:02 PM | #5 |
Oh and put the nut back on the ground post (remove last) while you take off the two plastic washer nuts. Helps from the tach head getting away from you while fighting with the 12v and coil posts.
05-28-2018, 11:13 PM | #6 |
Cluster King
Find someone with a lathe and have them turn down a 1/4 inch drive 3/8, six point socket enough so that it fits down between the nut and the nylon washer.
Or, you can use a good set of needle nose and what ever Curt said
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
05-28-2018, 11:27 PM | #7 |
The Older Generation
I bought a cheap nutdriver at a swap meet and ground the outside down on the bench grinder 'till it fit. LockDoc
05-30-2018, 10:04 AM | #8 |
Thanks for the replys, I'm going to try a few things from your suggestions
