05-30-2018, 02:08 AM | #1 |
wiper parts
Hey guy's I want to replace all of my wiper parts linkage assembly , pump and wiper motor, because this is a new cab and I don't know the condition of the wiper parts It would be better to change now than later there are nothing under the dash in the way. there is a 2 pin motor currently mounted. Can I replace the motor with a 3 or 4 pin motor so I can have more than one wiper speed. I am going to rewire the truck any ways with a painless wiring harness P/N 10206 I would thank that harness will have the option to support either motor you want to use can anyone help me out on this before I buy anything
05-30-2018, 11:09 AM | #2 | |
The Older Generation
Re: wiper parts
All '67-'72 wiper motors are 2 speed motors. I'm not sure what you mean by 2 pin. Look through this thread and see if it helps. There are quite a few pictures throughout the thread. http://67-72chevytrucks.com/vboard/s...d.php?t=413551 There is a member on the parts board selling wiper delay kits for our trucks also..... LockDoc
05-30-2018, 01:22 PM | #3 | |
Re: wiper parts
05-31-2018, 12:03 AM | #4 |
Re: wiper parts
I removed the motor from the dash and found the three terminal at the top of the wiper motor the two I was speaking of was for the pump I guest those was the only ones I could see when the unit was bolted up so right now I am good thanks
05-31-2018, 12:15 AM | #5 | |
Re: wiper parts
Good deal. Yes, it is hard to see all of the terminals when it is bolted in. LockDoc
05-31-2018, 12:41 AM | #6 |
Re: wiper parts
05-31-2018, 10:10 AM | #7 | |
Re: wiper parts
LockDoc
05-31-2018, 10:45 AM | #8 |
Re: wiper parts
My son installed the Painless 10206 chassis harness in my 1971. I helped a tiny, tiny bit so I am not real versed on some of the fine details of this kit, but I do know everything was labeled and he did not have to modify anything, other than attach cable ends, to get it to work. It was very straight forward. I bought a loom kit and the Easy Install Tool p/n 70941 which sped-up installing the wires in the loom. Every wire has been loomed, with loom left over. I highly recommend the Painless products.
05-31-2018, 10:59 AM | #9 | |
Re: wiper parts
