Old 05-31-2018, 07:45 AM   #1
70GMCer
70GMCer's Avatar
Rear Sliding Glass Repair
My 83 has the factory original rear sliding glass & the windows channel seals are toast.
Otherwise, the assembly is in good shape.
Can these rear sliders be repaired with new channels with the assembly still attached to the cab?
I'm not talking about the window seal rubber. That's fine.
Just the channels that the glass rides on.
I haven't tried yet, but do the 2 glass pieces come out of the frame?
Anyone ever do this repair?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-31-2018, 08:14 AM   #2
TKCR
TKCR's Avatar
Re: Rear Sliding Glass Repair
Found this video on youtube, so I would say yes. But too find replacements, that might be the challenge.
https://www.youtube.com/watch?v=zMomkbpLh9g
Old 05-31-2018, 11:14 AM   #3
70GMCer
70GMCer's Avatar
Thanks for that link.
Looking at mine, it doesn't look like it comes apart like what was shown in the video.
Wondering if it's worth the time in trying to fix or just replace the whole thing...
1997 GMC Sierra Ext
1965 Mustang
Old 06-04-2018, 01:13 PM   #4
Pontiac1976
Pontiac1976's Avatar
A good glass shop should be able get the stuff or rebuild it for you. There two main types from Factory.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-04-2018, 08:23 PM   #5
HunterRotten
HunterRotten's Avatar
Try a glass shop like the guy above said. I have a window from CR Laurence. It's a good looking piece and works well on the bench but when it's installed it gets bound up easy like it's being squeezed in the window. It could just be my truck has tighter than normal clearances but thats my experiences with it so far.
HunterRotten is offline   Reply With Quote
