Old 05-31-2018, 11:48 AM   #1
G-NUT
G-NUT's Avatar
compression ratio on a stock 1985 C20 350
Anybody know the compression ratio of a stock 350 from a 1985 C20?
Thank you.
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
Old 05-31-2018, 02:36 PM   #2
Re: compression ratio on a stock 1985 C20 350
Depends on what version you have. Anywhere from 8.0 - 9.5 to 1 compression ration.
Compression check numbers are normally about 180-190
Old 05-31-2018, 10:10 PM   #3
G-NUT
G-NUT's Avatar
Thank you for the response.
Old 06-01-2018, 11:12 AM   #4
Keith Seymore
Keith Seymore's Avatar
The LT9 was the base 350 engine for Federal Emissions. Compression Ratio was 8.3:1
There was also an LS9 available for California only. Compression Ratio was 8.2:1
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-01-2018, 03:25 PM   #5
G-NUT
G-NUT's Avatar
Thanks for the info. I was looking into buying some heads and trying to decide between the 67cc or 76cc combustion chamber. World Products SR 170cc intake runner.
Old 06-01-2018, 05:06 PM   #6
G-NUT
G-NUT's Avatar
K
Thanks for that. I found the spec on the link you left. I have the LT9, 350 (M). Showed me my bore, stroke, compression ratio, all kinds of good stuff.
I appreciate it.
compression, compression ratio
