Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-16-2018, 10:07 PM   #1
prostreet1967
prostreet1967's Avatar
cutting weight
looking to start cutting weight on front of truck. currently weighs 3259 with me 1900# on front end. looking for most bang for the buck.
prostreet1967 is offline   Reply With Quote
Old 05-16-2018, 10:48 PM   #2
dangrebel
Re: cutting weight
what have you done so far?
dangrebel is offline   Reply With Quote
Old 05-17-2018, 08:04 AM   #3
Keith Seymore
Keith Seymore's Avatar
Re: cutting weight
3200 lbs sounds pretty good to me!
My race car is 3750 with me in it.
I'll follow along and see if I can offer anything (or steal any ideas) after you tell us what you've done so far.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-18-2018, 09:51 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: cutting weight
I'm always up for weight reduction, as long as it doesn't involve ME...or taking out my stereo.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-22-2018, 03:05 AM   #5
prostreet1967
Re: cutting weight
all stock up front no bumpers cut bed out some only one bucket seat
Old 05-22-2018, 03:06 AM   #6
prostreet1967
Re: cutting weight
here some pics
Old 05-24-2018, 04:07 AM   #7
Super73
Super73's Avatar
Re: cutting weight
You are close to where I was before I did the mustang 2 spindle on stock control arms with wilwood brakes. Last time out mine was 3120 with a full.14ga cell and full.15lb N20 bottle and my fat a$$
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-24-2018, 04:46 AM   #8
Killer Bee
Killer Bee's Avatar
Re: cutting weight
removable glass clip, lightweight version.. glass doors, and so on..
http://www.usbody.com/Pages_Trucks/60-Chevy.htm
finished pics here http://www.usbody.com/Pages_Info/F-CustomersPhotos.htm
how 'bout utoob of some passes? good luck!
Old 05-24-2018, 04:32 PM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: cutting weight
I was gonna say hood for sure and different hinges or pin on style .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 05-25-2018, 12:27 AM   #10
prostreet1967
Re: cutting weight
anyone ever fill tail gate with cement? wanna add 100 or so to rear.
Old 05-25-2018, 12:47 AM   #11
Killer Bee
Killer Bee's Avatar
Re: cutting weight
^ sounds a little impractical and too permanent to me.. also difficult to handle or remove..
mounting small cargo area for sand bags or mounts for tractor weights or exercise weights would be much easier and adjustable or completely removable..
good luck!
Old 05-25-2018, 10:34 AM   #12
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: cutting weight
Exercise weights bolted in with a hand style nut that can be removed without tools and possible a safety tractor pin .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-25-2018, 04:26 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: cutting weight
Lets just say that plumbing lead flows into lots of places if you can keep it warm.
Old 05-26-2018, 11:19 PM   #14
djracer
djracer's Avatar
Re: cutting weight
where is the battery. if not already there mou t it as far back to tailgate as you can. take weight off the nose or move back.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 05-30-2018, 12:51 AM   #15
prostreet1967
Re: cutting weight
battery is in front of passenger rear tire. didnt have alot of room behind tires but that is a option. wonder how much it would help moving from in front to behind tire
Old 06-01-2018, 06:44 AM   #16
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: cutting weight
What size is that rear tire and which tire is it ?
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-05-2018, 09:23 PM   #17
prostreet1967
Re: cutting weight
33x16.5 hoosier now
Old 06-08-2018, 07:41 AM   #18
bdiamond
Re: cutting weight
I've got 100-150 lbs of bolt on lead weights I used on my stock car I'd let go of cheap. I'm in Wichita Falls
bdiamond is offline   Reply With Quote
Old 06-14-2018, 01:00 AM   #19
prostreet1967
Re: cutting weight
how cheap?
Old 07-07-2018, 11:27 AM   #20
nxtruck
nxtruck's Avatar
Re: cutting weight
I know I'm a little late with this, but, I have a tailgate for my '66 that I filled the top half of it with lead shot. This added about 80 lbs. to it. Everything has to be sealed up tight, though, or the shot will leak out. I don't run this gate anymore, as I have worked on the suspension more and have it hooking w/o it. It does make a difference, though.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 07-07-2018, 11:43 AM   #21
nxtruck
nxtruck's Avatar
Re: cutting weight
Originally Posted by br3w city View Post
lets just say that plumbing lead flows into lots of places if you can keep it warm.
x2.
Chris
Old 07-08-2018, 07:38 PM   #22
Super73
Super73's Avatar
Re: cutting weight
I have 2 gates, one that is stock weight and one that I cut the top open and added about 100lbs of scrap plate steel I had laying around.
The heavy gate on and down changes the weight bias quite. 125% of the gates weight is seen on the rear tires while 25% of the gates weight come off the front tires. This is simply due to the weight being well behind the axle centerline, the leverage it has on the chassis.
