Old 06-10-2018, 10:41 PM   #1
playinsafe44
1950 3100 Door Adjustment
Hello everyone. I've been working on my old (very rusty) truck for a few months now. My goal is to complete all of the rust repair and get the cab structurally sound before moving on. I wanted to get the door to line up before I welded any more metal, but it's fighting me.
Before anyone asks... No, I did not brace this cab before cutting and welding. The front cab mounts were gone, most of the kick was gone, the lower hinge pockets gone, and the floor was covered in layered sheet metal and fiberglass. I keep looking for reference points, compare measurements side-to-side, and also compare to my dad's nearly rust free truck for reference. Hopefully this works out.
No matter how much I try to adjust this, I cannot get the belt line right on the doors. It appears as if my entire door needs to shift up, but there is not adjustment in the hinges (which are rebuilt). I assume the hinges have been tweaked over the years and need to be heated and bent up to raise the door. Is there something else I should try before I heat and bend the hinges?
playinsafe44 is offline   Reply With Quote
Old 06-10-2018, 11:19 PM   #2
MiraclePieCo
MiraclePieCo's Avatar
Re: 1950 3100 Door Adjustment
Hmm, what's that, about an eighth inch off? That's probably as good as the Chevy factory made them when new.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 06-11-2018, 11:44 AM   #3
playinsafe44
You're right. It's close, but of course we all get a little OCD on these things. This should end up better than original. It will just take me a few years...
Old 06-11-2018, 12:36 PM   #4
Driver_WT
Driver_WT's Avatar
That's what I was thinking. Build it and drive it is my philosophy
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 06-12-2018, 11:20 PM   #5
playinsafe44
Come on, there has to be someone that has experienced this before... Trust me, this looks worse in person haha
Old 06-18-2018, 12:43 PM   #6
keljay2004@msn.com
keljay2004@msn.com's Avatar
Ran into the same problem with my 49 3100. What I had to do was remove door and use a die grinder to make the holes in the door hinges longer, so I could tweak the door up in the back. You may have to remove some metal from both top and bottom hinges, to make door fit properly.
J T
keljay2004@msn.com is offline   Reply With Quote
