06-12-2018, 11:03 PM | #1 |
having a hard time. 700 and driveshaft
Im hooking up a 700 to my 292 and i cant find anything on whats necessary to make this possible. Tried the stovebolt site and the 12 bolt. It bolts right on but im afraid i will need a certain starter
also have no luck with a short bed driveshaft and i would not like to pay 300 if its still gonna have to b cut and balanced. Any help will b appreciated |
06-13-2018, 12:05 AM | #2 |
60-66 Nut
Re: having a hard time. 700 and driveshaft
Your biggest hurdle will be getting the TV cable connected with the correct geometry and properly adjusted. That is unless of course you have a 4bbl carb. For a starter all you need is one for the particular size flexplate you are using that bolts to the block. Just have your original driveshaft shortened to the correct length. That shouldn't cost anywhere near $300.
06-13-2018, 01:58 AM | #3 |
I’ve Always Paid 85.00 To Cut and Rebalance Driveshafts
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
06-13-2018, 09:25 AM | #4 |
1962 C-10
When you go to the parts store, ask for a starter for a vehicle that came with a 292 and an automatic.('69 C20, 292, powerglide). I want to say they are same as a starter for an SBC... straight across bolt pattern. Make sure you're running the correct flexplate too.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
