Vintage Air drain
I am installing a Vintage Air system in my 55 second series and was looking at the drain. Does anybody have a better way than just punching hole into fire wall? I went to get deal of work to clean my fire wall off and adding another line that just drips seems counterproductive. Been thinking of 3/8 line bent to follow the inside of the cab to the side vent and dropping the line in there. Bad idea? Other ideas? Pictures?
#2 | |
Re: Vintage Air drain
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
![]() Join Date: Mar 2011
Johns327, I did about the same as you said. Bent up tubing that comes thru the cab. It drains down behind the front tire. Here's a pic, hope this helps...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
I dumped mine into the wheel well thru the side cowl too.
not the best pic, i did the same as orrieg, under the unit out thru the side into the fender
you can see the black line in the kick vent my kick vents are cut out since i shaved the cowl vent
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Thanks all. I’m going to run mine out the vent as well.
