Old 06-15-2018, 09:47 PM   #1
ostie82
Help identifying, please!
Hello all,
I’m new to the forum and need a little help. I’ve been trying to buy a particular 1964 Chevy K10 for 10-15 years and finally have verbally purchased it over the phone. However, when I went to look at it, the VIN starts with “2C”. That should be sufficient enough to convince me that it isn’t a factory 4wd, but a couple of things don’t add up for me. 1) the truck has “knee-knickers”, which thought ended in 1963; 2) I’ve read that the VIN tag should be located on the driver’s side B pillar on a ‘64, but this one is located on the A-pillar, where it should be for a ‘60-63; 3) I know this one could easily be faked, but it has an original-looking 4wd operation sticker on the roof; 4) the body appears to fit the frame very well. If it is a conversion, it appears to have been well-done back in the day. My uncle owned the truck around 25 years ago and he was told it was an original 4wd when he bought it. Is there any additional ways to identity if it was originally a 4wd? I’m curious if the VIN tag was replaced. Also, the VIN on the from driver’s side frame rail is very hard to make out, but doesn’t appear to match the VIN in the door. Any guidance will be greatly appreciated.
ostie82 is offline   Reply With Quote
Old 06-15-2018, 09:51 PM   #2
ostie82
Re: Help identifying, please!
I’m trying to figure out how to upload pics
Old 06-15-2018, 10:04 PM   #3
ostie82
Maybe this will work
Old 06-15-2018, 10:38 PM   #4
gmcbigbl
gmcbigbl's Avatar
VIN Format: 1960-1964 Chevrolet Truck
Decoding: 2C144A120764
Digit Usage VIN Decoded
1 Year 2 1962
2 Type C Conventional (2WD)
3-4 Model 14 1/2-Ton, Standard Wheelbase
5 Body 4 Pickup
6 Plant A Atlanta GA
7-12 Sequential Serial # 120764 120764
gmcbigbl is offline   Reply With Quote
Old 06-15-2018, 10:49 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Frame should also have a VIN.
See if they match.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-15-2018, 11:20 PM   #6
ostie82
Here’s the VIN on the frame. Clearly doesn’t appear to match the VIN in the door, but I can’t make it out well. Is there a way to tell if this is a ‘60-66 4wd frame by the build? Also, would the VIN be in any other locations on the body? Under/behind the dash, etc?
Old 06-16-2018, 01:44 AM   #7
Captainfab
60-66 Nut
The cab is an original '62 2wd cab. I don't think the VIN tag has been messed with since it appears to still be spot welded. The hood is also a '62 and is possible the rest is as well. That is except for the '64-'66 grill. It's hard to say what the frame is without seeing more of it or the VIN on the frame. If the title has the cab VIN, that would likely be what matters unless you need a vehicle inspection to transfer the title and register in your state or county. Often times the inspector doesn't look at the frame VIN.
Old 06-16-2018, 01:45 AM   #8
andyh1956
If I remember right the cab supports from the frame that fit your cab are different from 64-66. Check the supports where they fasten to the frame & see if they are riveted or bolted.
Does that truck have a divorced transfer case?
andyh1956 is offline   Reply With Quote
Old 06-16-2018, 08:28 AM   #9
The Rocknrod
Moderator
The Rocknrod's Avatar
If I walked up to that truck I would tell you that I'm looking at a 1962 stepside with a 64 grill. That is obvious. As far as it being 4WD? Yo no say.
Old 06-16-2018, 02:02 PM   #10
61K10
61K10's Avatar
need running gear pics. Cab has probably been replaced. also clean off the frame #
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-16-2018, 02:13 PM   #11
LostMy65
LostMy65's Avatar
62 would be an x-frame.
Old 06-16-2018, 02:18 PM   #12
LostMy65
LostMy65's Avatar
The front bumper bolt spacing looks to be a 60-62.
http://67-72chevytrucks.com/vboard/s...ghlight=Bumper
Old 06-16-2018, 03:01 PM   #13
61K10
61K10's Avatar
No K10's were x frames. they were similar to a 1 ton.
1961 chevy K10
Old 06-16-2018, 03:33 PM   #14
LostMy65
LostMy65's Avatar
I did not know that.
Old 06-16-2018, 03:42 PM   #15
The Rocknrod
Moderator
Ah - the last two numbers on the frame - I see 45.
The last two on the VIN plate - 64.
Old 06-16-2018, 08:06 PM   #16
ostie82
Well, I decided to bring it home regardless. Hopefully I didn’t make a bad buy at $1,900. One way or another, it’s gonna be a nice ride for me one day 😎
Old 06-16-2018, 08:37 PM   #17
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
12 bolt rear with track bar eyelet intact. Think that has been changed as well.
Could you take pictures of the front diff to see if if it's open or closed.
Steering dampner was never an option.
Divorced transfer case?
Old 06-16-2018, 08:40 PM   #18
aerotruk63
aerotruk63's Avatar
Hub Lok option on front?
Old 06-16-2018, 08:41 PM   #19
aerotruk63
aerotruk63's Avatar
Under the hood and interior pics are required and requested.
Old 06-16-2018, 08:50 PM   #20
aerotruk63
aerotruk63's Avatar
1 Year 2 1962
5 Body 4 Pickup
2C as mentioned above
14 indicates 115" wheelbase
4 indicates that it came with a box , step or fleetside therefore not cab & chassis
A as above
1 all serial numbers of this era started with 1
20,764th truck produced at that plant.
Old 06-16-2018, 08:52 PM   #21
aerotruk63
aerotruk63's Avatar
Your dog really did a disfavor to the trim plate. lol
Paint code ?
Trim code?
Old 06-16-2018, 08:56 PM   #22
aerotruk63
aerotruk63's Avatar
Does not have a 62 crossmember below the engine.
Pictures of the front cab mounts please.
Old 06-16-2018, 09:22 PM   #23
pimpston65
pimpston65's Avatar
Is that K10 with ps?
pimpston65 is offline   Reply With Quote
Old 06-16-2018, 09:25 PM   #24
ostie82
Yes, it has a divorced t-case.
Old 06-16-2018, 09:31 PM   #25
aerotruk63
aerotruk63's Avatar
3 speed colum 4wd. Different.
