Gas Pedal Holes
Just Wondering What The Holes Around The Gas Pedal Are For?
I Upgraded To a Cable Setup Instead Of The Rod and Bought The Adapter Off A Site Member To Use It on My 69c10 Posted via Mobile Device |
Re: Gas Pedal Holes
The small holes in your pic are for the fire wall insulation retainers. The large hole by the three threaded holes is where the gas pedal linkage passes through (not used with a cable)
Here are some pics of a 72: |
Thank You
Old member
I bought the Lockar pedal assembly. I had the factory cable so it was a direct replacement. You will cover up the old rod hole and have to drill a new cable hole.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
