Old 06-20-2018, 01:55 PM   #1
motormouthfab
Neutral Safety Switch termination for Lokar Floor Shifter
C10 Guru's,
Looking for some help with the Neutral Safety Switch installation/wiring for the new Lokar floor shifter I just installed. I'm thinking I can land the switch wiring from my Lokar shifter NSS to the Ignition switch in place of where the stock neutral safety switch from the steering column lands right? I know where the switch is in the steering column but it is just wired to the ignition switch so it seems simple but just want some re-assurance and hopefully a pic/diagram on where to land my 2 wires from my Lokar NSS. Any help would be much appreciated as I have learned so much from this forum since purchasing my dream C10 about a year ago and diving in. Cheers
motormouthfab is offline   Reply With Quote
Old 06-20-2018, 01:58 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Neutral Safety Switch termination for Lokar Floor Shifter
I ran 2 wires from the stock NSS plug located under the dash, and ran them under the carpet to the micro switch on my B&M Pro Stick. Works perfect.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-20-2018, 03:44 PM   #3
72LB
72LB's Avatar
Same thing I did ran two wires from the NSS plug to the shifter.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
