06-20-2018, 02:35 PM | #251 |
Moderator
Re: Two is easier then one 1965 GMC S/W/BB build
Holes?
http://directsheetmetal.com/Store/in...roducts_id=172 It does look like a small block opening though.
06-20-2018, 05:05 PM | #252 | |
Sorry I was thinking of a different one, yes that is decent however we wanted to go all the way to the floor line and our transmission tunnel will need to tweak the heck out of that design. |
07-02-2018, 09:30 PM | #253 |
Well here is how we are doing it. This is our second attempt and it is coming out fantastic.
I am seriously slow at this type of work but I think my speed prevents us from rushing into a mistake. |
07-03-2018, 07:30 AM | #254 |
Fabrication work like this is very time consuming and for those that have not done it they don't fully understand how long it takes. Looking great
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
07-03-2018, 03:50 PM | #255 |
First mock up of the new firewall
07-08-2018, 01:54 PM | #256 |
Cleko's holding it in final position and Greg has trimmed it to fit.
Need to build the master cylinders bay for the Wilwood racing twins and finish the transmission tunnel and we are done. |
07-09-2018, 12:01 PM | #257 |
Wow. Absolutely stunning craftsmanship on the whole enchilada. Beautiful work. I just read the entire thread and will be watching closely for now on.
Brett | 1966 K20 - 292/SM420/T221 |
07-09-2018, 05:06 PM | #258 |
08-03-2018, 10:30 AM | #259 |
I have so much respect for the people that just build sheet metal from scratch. We flat suck at it. However we are really stubborn and have no problem throwing away weeks worth of work and starting over.
Due to the very tight conditions and the fact we have re invented the wheel so often on this build it comes as no surprise when bad planning and over estimation of our talents put us behind the proverbial 8 ball. I am talking about the master cylinders (Yep plural as we are running twins) and the steering column are fighting for their respective homes. Here are a few pictures to show our pain. went from this where it was fitted and tacked up To this where final welding and grinding gets us close enough to where it can be filled and painted. this is the well for the master cylinders This shows where we will be punching the steering column through. Can you feel our pain? |
08-03-2018, 10:45 AM | #260 |
Absolutely. It is a major undertaking to do stuff like that. It is also the most rewarding when you have a one off piece of work.
08-03-2018, 11:57 AM | #261 |
A little visualization of what we are doing
08-04-2018, 05:51 PM | #262 |
Getting close.
But one thing we are doing is sitting the engine back 2 1/2" so there is a couple more details to work out. |
08-04-2018, 08:40 PM | #263 |
Well this is it for the firewall.
Greg and I finished it up today. |
08-06-2018, 11:27 AM | #264 |
08-06-2018, 12:10 PM | #265 |
So when you fabbed the firewall, did you expect to shift the motor backwards and have to fab around it?
Otherwise, I continue to look in awe at all of your work.
Been a crazy 2018. Moved twice, back HOME in Oregon. Now to put everything back together, including the truck... My build thread for "Rocket" - http://67-72chevytrucks.com/vboard/s...d.php?t=753023 |
08-06-2018, 05:22 PM | #266 | |
So many things dictate the design and shape of the firewall. The floor around the throttle and below the brake peddle, as well as the height of the transmission. All told for something that looks so simple it can be a real head scratcher. |
08-06-2018, 05:36 PM | #267 |
Oh ok. I couldn't tell if the motor movement was a necessity because of the firewall or was planned. It looks beautiful. I still can't get over how good your metal work looks.
08-06-2018, 06:11 PM | #268 |
You are too kind, but the body man should be able to make our mess look good.
08-13-2018, 09:21 PM | #269 |
The cab is back on the rotisserie. We are now moving forward on the finalization of the interior. Greg has decided to go with a Vintage Air system for the creature comforts. We will need to create our own lower dash for the ducts.
Stay tuned |
08-14-2018, 08:11 AM | #270 |
Looking forward to it
09-04-2018, 10:07 AM | #271 |
09-05-2018, 05:31 PM | #272 |
Geesh
09-05-2018, 08:42 PM | #273 |
I watched it. Looks great.
09-06-2018, 10:10 AM | #274 |
09-06-2018, 01:28 PM | #275 |
I have noticed over the last few years that a lot of people have went to social media to keep up with projects. I don't have any SM so I still hang around here. A lot of people view threads and not reply. Reguardless of a forum foot traffic you guys are doing great work. When it's finished and going to shows is when it will really pay off.
