Old 06-22-2018, 09:05 AM   #1
rpmerf
rpmerf's Avatar
C20 Control arm differences
Can I bolt 73-87 C20 upper and lower control arms to my 1970 C20 cradle without drilling? If so, will the geometry be the same? Can I still use my 1970 springs?
Background:
I have a 1970 C20. I bought a 1983 C20 to sacrifice for my disc brake swap. The 83 comes with a new in box set of upper control arms with shafts and ball joints installed. I'm wondering if I can get a set of lowers and use them for the swap. I'd rather not swap the cradle. If swapping control arms doesn't work, I plan to install the 73-87 ball joints in my 1970 control arms.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 06-22-2018, 11:13 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: C20 Control arm differences
Yes, you can swap the arms to your 70 but you also need to swap all of the steering to the later model one or you might have to use adapters for connecting the inner and outer tie rods. Not 100% sure if this is the can on C20's but I know it is on C10's. If the C20's are like the C10's, you can actually put the later model ball joints into the original arms, if they are in good shape. Then use the later spindles/steering.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-23-2018, 05:45 PM   #3
AZ 67 C10
AZ 67 C10's Avatar
What's the difference in ball joints for the later models? Bigger?
AZ 67 C10 is offline   Reply With Quote
Old 06-25-2018, 10:38 AM   #4
chevy_mike
chevy_mike's Avatar
I am not sure about the C20 stuff, as I am not as familiar but I know the C10 stuff, yes the ball joints were bigger.
Old 06-27-2018, 09:09 PM   #5
LoX_69
LoX_69's Avatar
From what I vaguely remember the +73 ball joints are have a larger diameter shank. On my 69 C20 I used the original control arms and replaced the ball joints in order to use the +73 spindle/Disc brake assy I got from a donor truck.
LoX_69 is offline   Reply With Quote
Old 06-28-2018, 01:52 PM   #6
rpmerf
rpmerf's Avatar
Thank you. I will try bolting in the new arms when I do the swap.
1997 GMC Suburban
Old 06-28-2018, 02:01 PM   #7
chevy_mike
chevy_mike's Avatar
Yeah, I should have been clearer, the shank is bigger, I think the actual ball joint part to fit the a-arm hole is the same.
Old 07-06-2018, 01:26 PM   #8
Bentbolt
I tried to put 73-87 arms on my 65 and the center to center of the hole in my crossmember are different then the Ubolts I got.
Bentbolt is offline   Reply With Quote
c20, control arms, disc brake conversion
