Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-22-2018, 01:13 PM   #1
shootracing22
How to rollerize a 4l80e
I have a 1989 v3500 Chevy 4x4 square body crew cab that I swapped in a 12 valve Cummins and a stock 4l80e that was pulled from a low mileage 2003 box van. The Cummins is currently making in the neighbor hood of 400hp and 1100ft lbs of torque at a very low RPM (max torque is usually made in the 2000rpm range). I am using a TCI EZ TCU by Fast to control it.
I haven't pulled it apart yet and needless to say the stock transmission did not last. Under full throttle 1st gear pulled strong, 2nd felt like it slipped, the converter lock up was not as firm as it once was and with the converter locked the truck didn't set you back like it once did. Now its not making any line pressure after idling in the yard I want to attempt to build if right this time around. I plan to go with a tripple disk converter tuned and built for the Cummins powerband.
My main goal is dependability with crisp shifts with out being to harsh since this is often used for the occasional under 10k light towing daily driver often ran in Over drive, and I am hoping the 4l80e is capable of this.
I recently ordered a Stage 5 kit from Jakes Performance with a valve body re-calibration kit that blocks off the accumulators. I plan on using the ATRA manual for most of the rebuild.
I have a few questions before making my order I really need experienced opinions on.
1.) With my application at a Low 2000RPM making 1100 ftlbs of torque is it neccessary to rollerize the rear case bushing?
2.) On my 2003 4l80e is stock rear case lube accumulator feed that lubes the rear case bushing sufficient or is it necessary to block the accumulator feed lube tube and run a early intermediate shaft and out put shaft?
3.) My plans are to run the Sonnax Smart-Tech Overrun Clutch Valve Kit Part No. 34200-40K. Running this kit do you think my late model overrun clutch will hold up or would it be wise to swap it to a early model overrun clutch? I have heard about one high HP application that it did well using this Sonnex kit.
4.) Any addtional parts or tips would you recommend for my build that is not included in the kit?
In advance I greatly appreciate any help. Like most people I am on a budget, my trucks is more of a hobbie I enjoy tinkering with but want to build it right. I built a few transmissions in the past and feel confident I can build this one by being thorough and paying close attention to detail.
2006 GMC X-cab Z71 5.3LS
1994 GMC 1500 LWB 2wd
1989 Chevy Crew v3500 4x4 12 valve Cummins swap
http://www.4btswaps.com/forum/showth...-for-feed-back
shootracing22 is offline   Reply With Quote
Old 06-22-2018, 11:20 PM   #2
Captainfab
60-66 Nut
Re: How to rollerize a 4l80e
You'll likely be more apt to get a response if you ask a mod to move this to the Engine and Drivetrain section. That is where the trans experts hang out.
Old 06-23-2018, 01:28 AM   #3
shootracing22
Smile Re: How to rollerize a 4l80e
Thanks CaptFab.
Old 06-23-2018, 01:19 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
I would call Jake up . He would be more than happy to answer these questions and help a customer . He will know the answers to your question also . Great guy .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
