06-23-2018, 09:35 AM | #5501 |
Re: Restoring Rusty
so $217 dollars later (yes more than what we paid for the transmission in the first place) see lesson #1 above, ha ha we had ourselves what we believe is a proper or more better transmission mounted shifter linkage - this one I was told came out of a Chevelle
06-23-2018, 09:57 AM | #5502 |
Re: Restoring Rusty
and this is what the shifter bits looked like when they arrived, can't wait to bolt them on and give them a go shiftin gears
hopefully they don't position the shifter too far back where we have bench seat clearance issues kinda cool that the eBayer threw in that white shifter ball, I happen to have a shifter stick that I hope will work so this should give me everything I need |
06-23-2018, 10:01 AM | #5503 |
Re: Restoring Rusty
Saginaw Specifics
When looking at a Saginaw transmission, the front input shaft will likely have one or multiple grooves cut around its diameter. These grooves are there to indicate the ratios of the gears inside the transmission. 0 grooves: First 2.84, Second 2.01, Third 1.34, Fourth, 1.00 1 groove: First 2.54, Second 1.84, Third 1.44, Fourth, 1.00 1 groove: First 2.54, Second 1.84, Third 1.32, Fourth, 1.00 2 grooves: First 3.11, Second 2.20, Third 1.47, Fourth, 1.00 3 grooves: First 3.50, Second 2.46, Third 1.65, Fourth, 1.00 (I believe ours has three grooves so it's this one) Last edited by Gregski; 12-07-2018 at 10:42 PM. |
06-23-2018, 09:01 PM | #5504 |
Re: Restoring Rusty
This ought to be fun. I’m watching. I know you are ready to cruise a new four speed.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
06-24-2018, 06:39 PM | #5505 |
Re: Restoring Rusty
so decided to clean the Saginaw four speed transmission a bit, using Mineral Spirits from Home Depot, a wire brush, and some paper towels
06-24-2018, 06:41 PM | #5506 |
Re: Restoring Rusty
remember our goal being: Progress Not Perfection
06-24-2018, 06:43 PM | #5507 |
Re: Restoring Rusty
and here it is with the Hurst four speed shifter linkage mounted and my old chrome HURST shifter installed, not sure if this stick will work/clear but we shall see, it does look pretty cool though
of course couldn't mount the white ball do to thread differences not only size but also pitch, coarse vs fine, it's not easy fellas, really wanted to see that ball atop the stick |
06-24-2018, 06:53 PM | #5508 |
Re: Restoring Rusty
When looking for a brand new Hurst shifter components I further learned there were two Saginaw transmission types the 441 and the 456.
Hurst makes linkage for the 441 but not for the 456. So naturally I believe I have the 456, lol. Though with that Chevelle style bracket I think it makes it a moot point as to which one I have the 441 vs the 456 as it mounts the shifter using the bracket and ignored the holes in the tailshaft. hope you is following all this it can get unnecesarily complicated and I still don't get how this is supposed to be a torque tube transmission as it accepts a regular Turbo 350 yoke and has a rear seal for an open shaft, but the graphic saying it could be off of a 1981-82 Camaro or Firebird makes me feel a bit warm and fuzzy inside |
06-25-2018, 10:39 AM | #5509 |
Moderator
Re: Restoring Rusty
The F-body torque tube mounts to the three holes on the bottom of the tailhousing.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
06-26-2018, 01:15 AM | #5510 |
Re: Restoring Rusty
06-26-2018, 01:36 AM | #5511 | |
Active Member
Re: Restoring Rusty
A bushing bolts to the tail housing of the transmission and then a link connects the rear axle to that bushing to control axle rotation. It's basically a type of 3 link suspension. Looks like the Vega had a torque arm suspension as well. I found this picture here. http://dave.h-body.org/H-body%20Conversion%20Tips.htm |
06-26-2018, 01:59 AM | #5512 | |
Re: Restoring Rusty
06-26-2018, 02:23 AM | #5513 | |
Active Member
Re: Restoring Rusty
07-05-2018, 03:28 PM | #5514 |
Re: Restoring Rusty
it's that time of year again Comrads, haha
07-05-2018, 05:26 PM | #5515 | |
Re: Restoring Rusty
The 3.50 first gear was used behind small six cyl engines, like the 250. Your 2.84 is probably right on the ragged edge for a 350, but I know you're a conservative driver.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
07-05-2018, 08:33 PM | #5516 |
Re: Restoring Rusty
Is that a current pic of Rusty? Man what happened to the hood? I still like seeing you taking Rusty camping.
07-05-2018, 10:46 PM | #5517 | |
Re: Restoring Rusty
peace and chicken grease, g |
07-11-2018, 03:20 AM | #5518 |
Re: Restoring Rusty
ha ha, yup, I almost chocked on my beer when I read that, sure thing I'm a super hypermiler, lol
07-11-2018, 03:25 AM | #5519 |
Re: Restoring Rusty
Rusty treated me to some scary transmission noises on the way to work this morning to where I had to limp it home after work. So I decided to open up Midnight Auto and go Def Con 4 on the ol' OD trans!
I lifted the truck up to the highest click on the Harbor Freight 6 ton jacks and went to town at nearly 10 PM it was still almost 80* F Last edited by Gregski; 07-11-2018 at 03:41 AM. |
07-11-2018, 03:29 AM | #5520 |
Re: Restoring Rusty
How does a one man with a bad elbow git the trans out by himself without a proper transmission jack you ask?
Introducing the Semi Fully Adjustable TransJack 3000... suitable for the semi amateur casual transmission swapper brought to you by Pollack Potrafi (TM) |
07-11-2018, 03:31 AM | #5521 |
Re: Restoring Rusty
and two short hours later she was out
Profanity Disbursement = Minimal |
07-11-2018, 03:35 AM | #5522 |
Re: Restoring Rusty
mandatory stare and compare of the GM New Process NV833 and the Saginaw 4 Speed
hard to tell from the pics but they is nearly identical at roughly 21 5/16 inches long from bell housing to tailshaft end |
07-11-2018, 03:37 AM | #5523 |
Re: Restoring Rusty
doing my best here to hold the squigly measuring tape with one hand and snap the pic with the other
07-11-2018, 09:34 PM | #5524 | |
Re: Restoring Rusty
https://www.northerntool.com/shop/to...hoCUsUQAvD_BwE
07-11-2018, 10:35 PM | #5525 | |
Re: Restoring Rusty
