Old 06-25-2018, 09:52 AM   #1
fredhlynch2
Drill The Brake Pedal
So,
Getting ready to drill my brake pedal for power brakes. I get drilling it one inch lower than the original brake rod hole but where on the pedal? To the front, in the center or towards the back? Seems you would get more pedal travel to the master if it the new hole was to the rear (closer to the driver) of the pedal as opposed to a front or center position?
fredhlynch2 is offline   Reply With Quote
Old 06-25-2018, 10:32 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Drill The Brake Pedal
Drill it centered, like the original hole. You want equal amounts of metal so you don't create a weak point and cause it to crack. It does not make any more travel, that will only happen if you lower the hole more. All it would do is change the length of the rod.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-28-2018, 04:06 AM   #3
stsalvage
Scrapper 1
stsalvage's Avatar
there is one bolt hole that you can use to lone up your booster that's how we all did it
stsalvage is offline   Reply With Quote
Old 06-29-2018, 02:19 PM   #4
theastronaut
theastronaut's Avatar
Are the brakes overboosted/too soft if you use the original hole?
theastronaut is offline   Reply With Quote
Old 06-30-2018, 12:26 AM   #5
fredhlynch2
The brakes are not too soft. What I am experiencing is the brake pedal engaging too close to the floor. Maybe 2 inches from bottom. I have checked the booster to pin clearance and that's good. I bought the gage tool to be sure it was perfect.. I have the new Baer Master cylinder and prop valve with a new 90's Chevy booster, Capt Fab booster bracket and all new lines. I was careful to make sure the brake rod was not engaging the booster and leaking vacuum before pedal engagement.
The brakes are all new huge Bear disc units front and rear. There is just too much pedal travel before engagement.
Old 06-30-2018, 01:10 AM   #6
keepinitgoin
Try adjusting the brake pedal push rod a little longer, and see if the brakes engage higher up in your pedal stroke instead of almost to the floor.
keepinitgoin is offline   Reply With Quote
Old 07-01-2018, 12:48 AM   #7
Captainfab
60-66 Nut
Drilling a hole 1" lower on the pedal and connecting the booster pushrod there will correct some of your issue.
Old 07-01-2018, 03:01 AM   #8
fredhlynch2
Thanks Captainfab!
Old 07-05-2018, 07:47 PM   #9
karlbenz
I used the original hole. I didn't have an issue
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 07-07-2018, 03:39 PM   #10
keepinitgoin
I also used the original hole in my brake pedal arm, like you did Karlbenz. Works good for me so far, with 250 miles of around town and some highway driving. Captain Fab's vacuum booster to firewall bracket lined up my booster and MC with the pedal push rod at a good perpendicular angle so haven't needed to drill another hole an inch lower. Was originally a non booster brake 63 C10 truck and pedal.
Also, check your back brakes to make sure they are in adjustment, especially if it is drum rear and non auto adjusting shoes.
Check your Park brake adjustment too. My driver side E brake cable was sticking in it's housing, giving me uneven rear driver side brake shoe adjustment.
