Old 06-26-2018, 03:29 AM   #1
Dodge68charger
Kick Panel Speaker Ideas
Id Like To Put Some Speakers In The Kick Panel Area of My 70 c10. Anyone do Something Different Than Buying The After market ones.
Might Modify My Ebrake To Move It To The Right Side More To Get Some Bigger Speakers In There If i Have To. Thanks
Dodge68charger is offline   Reply With Quote
Old 06-26-2018, 08:34 AM   #2
MattPSU
MattPSU's Avatar
Re: Kick Panel Speaker Ideas
I made my own. Wood construction, covered in fiberglass, then body worked and painted body color. I also deleted my emergency brake and moved my high beam switch a little so they would fit.
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 06-26-2018, 09:45 AM   #3
Old_Gold
Old_Gold's Avatar
Nice!
Old_Gold is offline   Reply With Quote
Old 06-26-2018, 10:11 AM   #4
Dodge68charger
Looks Great. How Did U Fasten Them?
Old 06-27-2018, 07:50 AM   #5
MattPSU
MattPSU's Avatar
Believe it or not, I used Heavy duty Vecro to hold them in place. Works great.
Old 06-27-2018, 09:16 AM   #6
engineer_gregh
engineer_gregh's Avatar
Serious skills! Those look great.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 06-28-2018, 10:53 AM   #7
diggerbob
diggerbob's Avatar
That's about the best I have seen. You oughta make me a pair!
diggerbob is offline   Reply With Quote
Old 07-03-2018, 10:43 AM   #8
Tork?
Atomic Armadillo Metal Fab I follow them on Instagram. Small business handmade in Wisconsin. Some other cool custom bits available by them and reasonable prices considering the skill and work involved.
Tork? is offline   Reply With Quote
Old 07-03-2018, 02:46 PM   #9
FL71C10
Do those clear the e-brake pedal?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 07-03-2018, 04:06 PM   #10
Tork?
I recommend check out their website and send a message the guy is very responsive and interactive on Instagram
Old 07-05-2018, 09:51 PM   #11
68c10airstream
68c10airstream's Avatar
I went to tractor supply and bought small metal buckets with the bottom just a little wider than the speaker diameter. Used tin snips and cut slits down the sides of the buckets and carefully bent them at 90 degrees and got the buckets to be tilted up at me. Mounted to a 3/4" mdf board and cut the bottom out of the bucket, leaving a mounting flange behind. Bought a gallon of body filler from evercoat (on going special for years for $20.00) and moulded in the tin buckets to the mdf board because i haven't done a job in fiberglass yet. Sanded and painted to match the truck, put a little fiberfill inside the hole before i installed the speaker.
I angled the speakers so the p/s is pointed at my face and the d/s panel is angled to passenger face. Both the fiberfill and the weight and mass of the body filler and mdf help with the bass notes. Used the speaker hole to hide the mounting screws.
68c10airstream is offline   Reply With Quote
