Old 06-26-2018, 11:48 PM   #1
Blue GMC
Blue GMC's Avatar
What did I blow up now
Took out the 71 this weekend and she was acting weird. Accelerate from 0-30 fine then sputtered from 30 to 38 then ran like it rear was on fire until 50 then did the same thing until 58 mph. When it was sputtering was blowing black smoke like a diesel. No problems going up and down the rpm band while in park.
Running a 350/350 combo and both were rebuilt 528 miles ago but long enough to have no warranty. Truck does sit a bunch but has never acted up before.
Blue GMC is offline   Reply With Quote
Old 06-27-2018, 02:05 AM   #2
WhiteCST
WhiteCST's Avatar
Re: What did I blow up now
Timing chain intermittently slipping under load maybe?
1953 Kaiser Manhattan “Sled”
1968 C10 CST LWB
1991 Trans Am GTA “White Nasty”
2006 Dodge Charger RT
Built TH400 for Sale
WhiteCST is offline   Reply With Quote
Old 06-27-2018, 02:37 AM   #3
RustyPile
RustyPile's Avatar
Timing chain can't "slip" and then miraculously "retime" itself.. My money's on an ignition problem.. You say the truck sits a lot?? How old is the gas in the tank??
RustyPile is offline   Reply With Quote
Old 06-27-2018, 07:47 AM   #4
Blue GMC
Blue GMC's Avatar
Gas is about 6 months old but has stabil in the tank
Old 06-27-2018, 08:32 AM   #5
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
What's the initial timing? What carb? And some rebuild details like was a new cam and lifters installed and properly broken in? Pull the valve covers and check the rockers and springs...?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 06-27-2018, 08:40 AM   #6
Rich69shortfleet
HEI? Cheap HEI module in the HEI?
Rich69shortfleet is offline   Reply With Quote
Old 06-27-2018, 10:25 AM   #7
Blue GMC
Blue GMC's Avatar
Running an Edelbrock 1405 carb. Engine was ran for the first 300 miles with break in oil then drained and the valves were adjusted and the oil was switched to Mobil 1. Details I remember from rebuild are few as the paperwork was lost last year when basement flooded. But running a mild can upgrade with cast votrec heads bored .60 over. Trans has a stage 2 shift kit and a 2200 stall. Builder said had to have an octane booster added with each tank as 92 octane would not cut it
Old 06-27-2018, 10:26 AM   #8
Blue GMC
Blue GMC's Avatar
New AC Delco hei was placed and all wiring replaced.
Old 06-27-2018, 10:29 AM   #9
Wrenchbender Ret
Hi neighbor. The black smoke makes it seem like a carb problem. I'm thinking the choke is going off & taking a set. Some of those from that era had a spring around the choke pulloff. If the choke didn't heat up enough the spring would close it.
George
Wrenchbender Ret is offline   Reply With Quote
Old 06-27-2018, 11:08 AM   #10
truckster
truckster's Avatar
George
1405 should be a manual choke. Is the choke all the way open?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 06-27-2018, 11:24 AM   #11
68 P.O.S.
What is your timing set at? Get your timing set correctly first, then you can move on to the carb.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 06-27-2018, 07:30 PM   #12
Blue GMC
Blue GMC's Avatar
That's now the plan this weekend then follow up with the carb. Vehicle is at my in laws right now so has to wait a few days. Miss read the carb model(dang bad eyes) and it is the 1406 with the electric choke.
Old 06-27-2018, 08:23 PM   #13
hjewell2
hjewell2's Avatar
was it stabil 360 by chance?
hjewell2 is offline   Reply With Quote
Old 06-27-2018, 09:25 PM   #14
Steve78LT
I had an HEI coil start to go bad on me and act the same way. Lots of backfiring though as the raw gas which made it into the exhaust pipes would get lit off when the coil cam back on. Ultimately traced it to one of the wires which plugs into the bottom of the distributor cap being loose.
- Just a dad helping his
16 year old build a '72
he bought himself
Steve78LT is offline   Reply With Quote
Old 06-27-2018, 09:49 PM   #15
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Was the cam properly broke in if it is a new flat tappet? And unless you're running 11:1 compression or higher you won't need octane boost. I have a very snotty 355 in my truck, and at 10:1 compression with a wicked cam for the street, I can run 92 octane right out of the pump no problem.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-27-2018, 11:27 PM   #16
prodjay10
Dirty gas tank?
prodjay10 is offline   Reply With Quote
Old 06-28-2018, 08:30 AM   #17
Rich69shortfleet
Change the fuel filter at the carb and check out the HEI cap, rotor and coil for problems. Make sure the ignition module has the proper heat sink goo on the bottom of it.
Old 06-28-2018, 12:26 PM   #18
garyd1961
I would drain the tank and put fresh fuel in it.
garyd1961 is offline   Reply With Quote
Old 06-28-2018, 01:24 PM   #19
BrianG
BrianG's Avatar
Gary
I agree. Based on the description of the rebuild, I would think it should run fine on even 89 octane. Also that seems way too soon to switch to Mobile 1. But I’m sure there are many different opinions on that. I’d pull the plugs and see what they are telling you. Post a pic or two of them.
Edit... also what is your TOTAL timing? I think the Vortec heads require it to not be too high.
BrianG is offline   Reply With Quote
Old 06-28-2018, 02:55 PM   #20
Rich69shortfleet
Change the fuel filter.
Old 06-28-2018, 04:53 PM   #21
garyd1961
Old gas, water in tank?
See it quite often at work
Old 06-28-2018, 08:26 PM   #22
GASoline71
GASoline71's Avatar
Seen a lot of ignition modules burn up because cats will use dielectric grease instead of heat sink grease.
Gary
Old 06-29-2018, 03:18 AM   #23
stsalvage
Scrapper 1
stsalvage's Avatar
Did you for get to put the distributor bolt in and tighten it down
stsalvage is offline   Reply With Quote
Old 06-29-2018, 08:15 AM   #24
Blue GMC
Blue GMC's Avatar
Thanks for the help gives me a good place to start looks like next week I will start with:
1. Dump the gas tank(where to put 17 gallons of fuel that will be fun)
2. Replace fuel filter.
3. Go through hei and check wires ect.
4. Pull plugs and check probably just replace.
5. Check timing
Old 06-29-2018, 09:19 AM   #25
Rich69shortfleet
5. Check timing
Don't bother dumping the gas. Do the other things (change the fuel filter!) first and see how things go. I've used gas that is two year old and never had a problem. Bad gas certainly wouldn't make it run bad at certain RPMs and okay at others. You may have had junk in the tank which is why you want to change the fuel filter. Oh, did I mention, change the fuel filter. Then check and snug down all the HEI connections. Also, does the HEI have a clean 12v connection? If you connected the HEI via a resistance wire or the wiring you are using is weak or not well connected, fix that right away.
