Engine Accessory Decision
Getting close to swapping engines in Zane's 71. Truck has power steering and AC. The new engine was pulled from a 2001 3/4 ton van; not LS engine, Vortec. I have all the accessories used in the van for AC, power steering, alternator, brackets, etc.
Looking for feedback from the collective group. Should I stick with the stock v-belt setup or switch over to the newer (maybe not in miles) setup with rib belt, etc. What obstacles would I run in to if I switch? Thinking power steering fittings will be different, but might be able to swap fitting on back of pump to new pump or have new hoses made up with correct fittings. What about alternator? Any wiring changes necessary? What about AC setup? The current AC is complete, but not used in 25 years.
Zane's 71 Build |
![]() Join Date: Mar 2014
Re: Engine Accessory Decision
I did this exact swap in my 68 and chose to use the serpentine belt (groved) form the vortec. If you have all the brackets and accessories from the vortec use them. The serpentine (grooved belt) setup is much better and frees up about 15hp. You can change fittings on the back of the power steering pump and use a hose from a newer C10 or change the pully on your existing pump, either way you will need the hose for a newer C10. I used the Vortec AC compressor with the trucks existing Vintage Air AC kit. You should be able to use the vortec compressor with your existing AC but your 25 year old system may need some repairs.
Which alternator do you use now? Wiring all depends on your current setup. If you would like some pictures of more info let me know. I believe hose power steering hose I used was for a 80's C10. I found the info for the hose somewhere on this site when researching the GM serpentine belt conversion.
Made in America by Americans |
Thanks for the info. Quick search shows tons of info. Going with the late model stuff.
I should have searched prior to posting. I guess if everyone searched first, there would be no new threads. ![]()
Zane's 71 Build |
Found all the info I needed in this thread.
http://67-72chevytrucks.com/vboard/s...86#post8341186
Zane's 71 Build |
Still plays with trucks
After wasting too much time dealing with the failure prone CS-130 alternator that is stock on the Vortec 350 I suggest you get the parts to use the optional CS-144 alternator that is a much better design and far more durable.
You also get the added benefit of a higher amp output capacity too. I have converted four rigs of mine to use it now, soon to be five. I will never build another vehicle with a CS-130 on it. From the start they will all have a CS-144.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
Moderator
![]() Join Date: Jun 2017
If you do decide to use the Vortec rib belt system...make sure you get the correct water pump...
rib belt water pump systems rotate backwards to a V belt system... Probably preaching to the converted,,,but anyways... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
The engine and accessories all came out of a 2002 3/4 van. No issues with waterpump, etc. Electronic wise, there was some weird cross over stuff. Computer was the 411 like an LS engine, wiring did not match the trucks of 1998 generation.
Since you are volunteering info...what alternator do I have in the pick. Do you know anything about the AC compressor. Besides the two plugs on top, it has a two pin on the back.
Zane's 71 Build |
#8 | |
The earliest rib belt setups were conventional not serpentine. This is true of ‘86 Camaro/Firebirds and trucks I know. Not sure first year of true serpentine setup. I think ‘88 on F body? Not sure on trucks, but vans were the red-headed step child often not getting the upgrades the other lines got until years later. It was common with racers I knew to run the grooved non-serpentine setups because the extra rubber contact could take a greater load before belt slippage. The 2001 is almost certainly reverse rotation true serpentine setup. But you never know...
